Air induction - need to connect
Discussion in 'Troubleshooting & Diagnosis' started by JD Z, Aug 22, 2017.
  1. JD Z
    JD Z Veteran Member
    The air induction is not connected on my 1980 Z. The connections I see are attached. Suggestions on what I need to do in order to hook up and test?
    Seems the ground I need to attach somewhere on the hood. The remaining wire in the hood doesn't look like it will make a direct connection to the wire coming from inside the car. Is there a connector Im missing? Should I just wire together old school ways? Thanks all. Justin
