Air Compressor Location
Discussion in 'Garages, Workshops & Tools' started by BamaRocker, Jun 20, 2013.
  1. 5spd540
    12,344
    12
    Sep 19, 2009
    Guyton, GA
    I put mine in the corner of my shop close to the panel box
  2. Mike N
    Mike N Moderator Staff Member Lifetime Gold Member
    2,254
    275
    Jan 13, 2002
    Spencerport, NY.
    Basement. It's a 5 horse 60 gallon upright compressor. No room for it in the garage and I prefer it to be in a stable temperature. I ran a hard line from the compressor thru the wall into the garage and all is well.
  3. 1971CamaroGuy
    1971CamaroGuy Veteran Member
    3,480
    86
    Oct 31, 2004
    Arkansas
    I put mine outside of my shop inside a lean to with a concrete floor built by the previous owner.
    The exact location was decided because there is a fuse panel right behind where it's sitting...I just tapped for 220 and went straight through the wall with a receptacle mounted on the wall for the compressor to plug into.
    I also screwed it down to a homemade wood pallet with foam cushion to keep it still and help with noise and vibrations
