Aftermarket Trim
Discussion in 'Body Restoration' started by Plater Tom, Nov 30, 2017.
  1. Plater Tom
    Plater Tom Veteran Member
    1,331
    13
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    Does anyone know if Front and Rear Window Trim is made by more than one company, or are there different/better brands to buy. Have heard stories that some are better than others when it comes to fit and thickness. Tom
  2. phat80
    phat80 Veteran Member
    1,019
    10
    Jan 4, 2013
    Victoria BC
    I'm watchin this 'cause I'm just in the process of pricing out new trim. It is EXPENSIVE!
  3. Plater Tom
    1,331
    13
    Feb 2, 2003
    I am a bit surprised that there have not been any comments. Tom
  4. CamarosRus
    CamarosRus Veteran Member
    Plater Tom, I cant remember your history or current plating/polishing status ???
    I have Good Sets of used OE Aluminum Clad Trim that needs to be polished after the anodizing is stripped.
  5. wnmech
    wnmech Veteran Member
    808
    53
    Jul 20, 2014
    grand prairie tx.
    I bought my aftermarket window trims for my 71 on ebay. I dont remember the vendor but I'm sure they all come from basically the same place. I ruined the rear window trim trying to do like the old days hitting the trim with my palm and ended up bending it at a $200 loss. I repurchased the trim from the same vendor and this time I used the window trim removal tool and released the pressure off of the window clip and my trim came out fine. Ultimately be careful installing those trims because the will bend easily.
  6. Plater Tom
    1,331
    13
    Feb 2, 2003
    Thank You for the information wnmech. I had been told in the past that the aftermarket trim was not the same thickness. Just wanted to verify that by another person. Chuck, I retired two years ago, therefor I am no longer involved in plating. I also have several sets of trim that I will be refinishing when time permits. Tom
  7. phat80
    1,019
    10
    Jan 4, 2013
    Victoria BC
    Would you in intersted in boxing up the trim and sending it to Blaine WA 93210? Thanks larryirvine@shaw.ca
  8. 80sz
    80sz Veteran Member
    2,769
    288
    Feb 2, 2014
    Buffalo,n.y.
    I bought new trim for rear glass . Like said it is thinner and bent when putting on. Finding good originals is a better option
