AEM wide band 30-4110?
Discussion in 'High Tech Retrofits' started by Dave Nelson, Oct 3, 2017.
  1. Dave Nelson
    3,429
    682
    Dec 19, 2003
    Vineland N.J USA
    Anyone using/tuning with this model (AEM 30-4110) if so how do you like it? Going on a carbureted motor.
  2. ULTM8Z
    ULTM8Z Veteran Member
    8,498
    122
    May 19, 2000
    Los Angeles
    I have a AEM WB. Works good. Been running it for about a year I guess. I routed the 5V output into the ECM and am able to record output on the data acquisition system through the data port
  3. rchydzik
    755
    10
    Nov 13, 1999
    Colbert, WA USA
    It has worked well for me.
  4. Todd80Z28
    10,976
    43
    Jun 11, 2002
    Northern VA
    Dave,
    I have one just like that, maybe slightly older model- 30-4100.
    Here's my install from a few years ago- Oct 20, 2012
    I took it out about 2 years ago and put it in a buddy's car temporarily to sort out tuning issues (the black 3rd gen TPI car, if you recall). It's in my trunk, haven't wired it back in yet.
    Where are you going to put the gauge? I had it temporarily on the column, but it wasn't my favorite spot.
  5. ULTM8Z
    8,498
    122
    May 19, 2000
    Los Angeles
    Yeah, btw... whatever happened with his car anyway?
  6. Todd80Z28
    10,976
    43
    Jun 11, 2002
    Northern VA
    Well, it runs great, needs a couple of small things sorted out. But he is SO done with the car that it’s been sitting in the work parking lot for 8 months. He wants to sell, no motivation to even do that.
  7. ULTM8Z
    8,498
    122
    May 19, 2000
    Los Angeles
    I can imagine the frustration after everything we went through trying to sort out the tune...
  8. BonzoHansen
    $2500. :)
  9. John Wright
    14,108
    72
    Aug 9, 2002
    Rustburg, Va
    I'm running one of those AEM widebands....works pretty good. I have the stock narrowband on one side and the wideband on the other.
  10. Dave Nelson
    3,429
    682
    Dec 19, 2003
    Vineland N.J USA
    After several trips and adjustments on the Quadrajet, I think the tune is very close. Cruise #'s are 14-14.8 depending on rpm, wot 11.8-12.8,the idle is 13.0-13.5 but that is as lean as I can a get it. Carb is fairly stock, AX secondary rods, went to 47B primary rods from 49B with 78 jets.
