Advance Timing Light suggestions?
Discussion in 'Garages, Workshops & Tools' started by Todd80Z28, May 28, 2014.
  1. Todd80Z28
    10,923
    33
    Jun 11, 2002
    Northern VA
  2. COPO
    16,248
    239
    I like non digital lights. Less options means less things that will go wrong.
  3. speed_m5
    speed_m5 Veteran Member
    1,051
    12
    Apr 17, 2010
    Baytown Texas
    If you are using any MSD stuff Don't use the dial back version
  4. CorkyE
    9,210
    215
    Todd, if this is for your car with HEI, the first one should work fine. I think the pro version is constructed a bit heavier to withstand daily use.
  5. FatnLow
    1,949
    Mar 12, 2003
    Montgomery, AL US
  6. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    I have had the equus 3568+ digital advance timing light for close to 10 years and it still works great. I have used it on everything from stock HEI, points, MSD, and Mallory systems
  7. arick793
    arick793 Veteran Member
    1,108
    Oct 27, 2008
    Rochester, NY
    I've read that dial back timing lights are only accurate to a certain RPM. That rumor was enough for me to buy a $3 timing tape and use a standard timing gun
  8. ULTM8Z
    ULTM8Z Veteran Member
    8,463
    101
    May 19, 2000
    Los Angeles
  9. grzewnicki
    Why not? I know the instructions say not to just wondering why. And can you use a dial back but not dial it back?
  10. grzewnicki
    if anyone is interested,
    found the answer, on another forum
    We recommend using non-adjustable timing lights because of their analog circuitry design. Adjustbale digital type lights tend to pick up interference from the MSD and can be off as much as 1 degree per thousand RPM.
    Also some info here where people are using them with no problems.
