Accelerator pedal.........
Discussion in 'Interior Restoration' started by Smokey15, Nov 13, 2017.
  1. FlaJunkie
    5,978
    93
    Mar 24, 2001
    Rockledge, Florida
    Mine had no screw in the middle of the plate either.
  2. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    Hole or no hole in the support (plate)?
  3. l16pilot
    1,613
    79
    Dec 13, 2004
    Hurlock, MD, USA
    Joe - the photo I posted are not OEM items...the floor bracket and throttle rod in the image are the items I reproduce. When I made the floor bracket, I did not include the center hole, yet all originals I have have that hole...and one had the self tapping screw actually installed...I believe it was out of my 04D Norwood 70Z. Much like Dave rationalized, I believe the center hold was used to fixture or fasten the floor bracket so an assembly line worker could install the nuts without having someone on the interior push it through and hold....but they likely found it took more time to install the center screw than to just have someone hold it for a couple of seconds....again, just a guess, as I've seen some original 70Zs that never had the center hold pierced or threaded in the floor toe board.
  4. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    I’d guessed it was your part ;) but I’d also guessed that Mark doesn’t have your part installed in his car...no hole there. I could be off in my guess about Mark’s photo, I’m sure he’ll chime in. I can see the bottom of my 70, I’ll see what I can see when next I am in that garage.
  5. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    79C2C93F-E741-46E5-854C-795862A71743.jpeg It seems to me that the hole should be in the support but not always the floor...one of the many body piercings done on the assembly line. Mine has the hole in the support and the body piercing but no screw.
  6. FlaJunkie
    5,978
    93
    Mar 24, 2001
    Rockledge, Florida
    No hole.
  7. Budz
    2,928
    36
    Mar 17, 2002
    Ashburn, Va USA
    I just looked at mine from underneath and it has a partial piercing from the interior, but it is not punched all the way through, so 'no hole' at the screw #4 location. I don't know if the support has a hole for the screw, or if the ball studs are welded on as I've never had the pedal off. '70 Norwood 04D
  8. COPO
    16,399
    283
    I have no hole in my plate and it's orig to the car.
  9. 70lt1z28
    2,045
    262
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Mine is like Buddy's. 04B Norwood car.
  10. Smokey15
    Smokey15 Veteran Member
    1,325
    621
    Aug 13, 2017
    This is the new piece of crap. No way would it ever stay on the ball studs. Didn't even have the rubber for under it. Also pic of the original. IMG_4508.JPG IMG_4509.JPG IMG_4510.JPG
