Aaron's 76 Type LT Project
Discussion in 'Project Progress' started by 76_TypeLT, Aug 1, 2008.
  1. perkalator
    perkalator Veteran Member
    937
    56
    Aug 27, 2014
    kennewick wa
    Congrats on the family and the advancement on your car. Your on the fast track..
  2. olstyle
    olstyle Veteran Member Lifetime Gold Member
    8,649
    Jan 27, 2008
    Crestwood IL.
    Wow Aaron seems I need to check in a little more often. Congrats on both :)
  3. Happy_Dan
    Happy_Dan Veteran Member
    628
    60
    Sep 13, 2013
    Litchfield, NH
    As the father of six daughters, my heartfelt congratulations! Little girls steal your heart and never give it back. If this is your first, you will find your whole perspective on life will change in and instant!
    Enjoy the whole experience, they grow up way too fast.
  4. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    960
    Apr 27, 2010
    Verona, ITALY
    Wow! Congrats on both!!!
  5. 76_TypeLT
    6,387
    135
    Jul 26, 2008
    Houston, TX
    Thanks guys, we are excited to add to the family. This is going to be it for us, mainly because my wife couldn't go through another pregnancy. This one was rough on her. She's 37 and I am 41, so 2 children is enough for us.
    perkalator likes this.
  6. JohnL71RS
    JohnL71RS Veteran Member
    1,606
    19
    Apr 12, 2010
    Marrero, LA
    congrats on the car starting. i know that feeling all too well. I wish all the best for the new addition to the family.
  7. 76_TypeLT
    6,387
    135
    Jul 26, 2008
    Houston, TX
    I was having issues with the oil pressure gauge and water temp gauge not working properly (Auto Meter Sport Comp II, electronic) and I got the water temp gauge to work but I am still messing with the oil pressure gauge. I kind of need that one to work. :)
    You have to apply teflon thread sealant on the adapters that thread into the motor since they are NPT fittings, but if you put too much sealant on them then that affects the ground which affects the gauge's ability to work properly. The oil pressure gauge wasn't moving at all last night, although it HAS worked properly before and showed 40 psi. I removed all the thread sealant last night and will try again tonight. I know I have oil pressure but I still need that gauge to function.
  8. Scott51
    Scott51 Veteran Member
    429
    24
    Jan 2, 2012
    New Zealand
    Adding one or two copper or aluminium washers can really help with grounding in some instances, but depends on the shape of the fittings
  9. PTC
    PTC New Member
    25
    Nov 13, 2011
    Kloogaranna
    Perhaps using some kind of liquid pipe sealer would make difference?
  10. 76_TypeLT
    6,387
    135
    Jul 26, 2008
    Houston, TX
    Good call. These adapters came with copper washers which I assumed was just for sealing but am now learning they help with grounding.
    I hooked the oil pressure guage back up and it works fine now. So that's a relief. It shows 40-45 psi.
