A little breakage at the track today
Discussion in 'Competition Camaros' started by Blown Camaro, Mar 4, 2018.
  1. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,183
    130
    Dec 13, 2009
    Deltona, FL
    20180304_171955.jpg 20180304_121043.jpg 20180304_103035.jpg 20180304_100829 (1).jpg 20180304_103007.jpg 20180304_162910.jpg 20180304_103233.jpg 20180304_103225.jpg 20180304_102954.jpg Beautiful weather, about 70 degrees and sunny. Nice 15mph tailwind. I did a 3rd gear burnout and warmed up the ET Street Radials. Track was fully "your shoes off" sticky. I launched and 2000rpm and flashed to 4200. Car hooked, front end started coming up, then it blew off the tires. So I pedaled it and it shook HARD. Pedaled it once more and >BANG!<. Pulled it to the side and no fluid on the track; but no ring & pinion connected in the 9 inch any more. :) Frickin tire shake. They saw it in the tower! Should have aborted - these radials are parts breakers when they do that. Here are some pics.
    Blower : 3
    Rearend : 0
  2. xten
    xten Veteran Member
    1,424
    619
    Sep 24, 2014
    Pittsburgh, Pa.
    Sorry to hear that...Sure looks good! I do it too. Should abort, you know the time slip's going in the garbage, but....
    Blown Camaro likes this.
  3. mrdragster1970
    Some bad ass fast cars there today.
    Have you looked into the 9 1/2 center section?? If you broke the 9" 3 times, it might be time to upgrade the center section??
    Good luck getting back out asap!!!!
  4. Blown Camaro
    1,183
    130
    Dec 13, 2009
    Deltona, FL
    Last time it broke the rear it took out EVERYTHING all the way to the converter. $$$$. I am really hoping it isn't that bad this time because the driveshaft is still in it and I did not zing the motor. This is a brand new billet FTI converter I sure hope it didn't balloon.
  5. mrdragster1970
    Quit making so much HP and you wouldn't have these issues :p
    jimrr likes this.
  6. Blown Camaro
    1,183
    130
    Dec 13, 2009
    Deltona, FL
    And it's only a small block! Hey, does that 9.5 fit in a standard 9.0 case? I found a used Mark Williams 3rd member with 7 passes on it. It's a bolt through of course. Only problem is it has an 1/8 mile gear in it.
  7. mrdragster1970
    I was told they do fit. Sometimes on a stock housing you have to do a small amount of trimming??
    They claim the ring is the only part different, slightly bigger, but everything else is same dimensions.
    I would definitely call the housing or spool company 1st, this is just what I read on yellow bullet.
    You do know Mark Williams uses a different axle than Strange & Moser.
    Like on my Pro-Mod, I have to have 2 sets of axles.
    If something happens to my M/W center section, my spare is a Strange and the axles do not interchange :(
    Same housing, both 40 spline, but they are different length's.
    Good luck.
  8. SRGN
    SRGN Veteran Member
    428
    133
    Feb 20, 2009
    Central NJ
    Spinning then hooking breaks a lot of stuff. I've been 1.18 60' on the rear tires with a 9", without breakage. I learned long ago it was a lot cheaper to just coast after I blew the tires off, unless it was a $$ or points race. I also had much better luck with CF driveshafts, they seem to dampen the shock to the rear much more than aluminum. Second choice is 4130.
    Blown Camaro and muscl car like this.
  9. Blown Camaro
    1,183
    130
    Dec 13, 2009
    Deltona, FL
    Worst tire shake I ever had after I pedaled it. 295/65/15 ET Street Radials with 20psi. Maybe I will put the 10.5 slicks back on it. It never shook those. I see it also broke the left rear shock, it's pissing oil. These were single adjustables I need to get some doubles on here.
  10. Mwilson
    Mwilson Veteran Member
    wow that car is nice
