A/C Spray Shield, from a 69?
Discussion in 'Engine Topic' started by Burd, Nov 5, 2017.
  1. Burd
    570
    97
    Oct 6, 2011
    I saw a Spray shield on a car at the Natz, he said it was a Camaro item, Ecklers has a re poop version, it looks like it'll keep 3/4 of the spray of oil off under the bonnet, the big A/C hose is in the way and it needs to be bent a tad, I'll let my mechanic do it, anyone use them here? It bolts to the hole/stud that's existing. Simple bolt on, if the hose has clearance.
  2. twozs
    twozs Veteran Member
    8,668
    130
    Aug 5, 1999
    hopewell jct ny
    Mines worked for 20 years and the oil sling should be minimal . And it only covers half the radius of the compressor pulley . If your slinging oil all around out of the ceramic compressor seal your compressor won’t last long . And I’ve never seen one stock on a second gen .
