882 to 186 heads. Any gains?
Discussion in '1970 - 1973 Specific' started by Bob1970sbc, Feb 22, 2018.
Tags:
  1. Lowend
    14,381
    253
    Mar 25, 1999
    San Jose, CA, USA
  2. Bob1970sbc
    Bob1970sbc New Member
    26
    Feb 22, 2018
    Thanks. I'll check them out
  3. Rich Schmidt
    Rich Schmidt Veteran Member
    4,215
    30
    Mar 27, 2010
    Denville NJ
    I would think that the heads would be worth a lot to the right 69 Z/@* guy. Probably enough to buy a set of new aluminum heads. If they have 1.94/1.50 valves it is even better since when the buyer has them rebuilt with the bigger valves the seats will be fresh and at the correct height.
  4. Zulu28
    Zulu28 Veteran Member
    217
    16
    Dec 19, 2013
    Vancouver, BC
    Exactly ^^^
    RV cams are designed for good torque in the lower rpm range, they also trap a lot of cylinder pressure, adding compression will create problems for sure.
