'81 LG4 Smog Pump Delete Belt
Discussion in 'Tips 'n' Tricks Topic' started by MP81, May 24, 2017.
  1. MP81
    MP81 Veteran Member
    151
    Oct 10, 2016
    Washington Township, MI
    Just curious if anyone has the belt length for an '81 LG4 after removing the smog pump. I'm starting on the header and exhaust install, so I will be removing the pump and the AIR system. Figured I'd check if someone had the proper belt length prior to measuring it.
    Thanks!
  2. Zspoiler
    Zspoiler Veteran Member
    2,317
    122
    May 6, 2012
    Federal Way, Washington
    Jus use a belt from a 1979 Z28 it did not have an A.I.R. pump
  3. MP81
    MP81 Veteran Member
    151
    Oct 10, 2016
    Rock Auto had one listed on the '81 page without an AIR pump, I think equal in length to the '79, and that worked perfectly.
    Well, almost perfectly, it squeals like a bitch now, but I think I need to tighten it up more, and make sure it isn't dirty.
