81 camaro berlinetta key stuck in on position
Discussion in 'Troubleshooting & Diagnosis' started by Fletch81, Apr 26, 2017.
Tags:
  1. Fletch81
    Fletch81 New Member
    9
    Apr 26, 2017
    The key is stuck in the on position... The car will run but i can't shut it off its never done this before i don't know what happened wether its jammed or not. i had to disconnect the battery to shut the car off
  2. Zspoiler
    Zspoiler Veteran Member
    2,836
    177
    May 6, 2012
    Federal Way, Washington
    The actual ignition switch is toward the bottom of the column.Is it adjusted correctly? Other wise you will have to pull off the steering wheel and look inside .To see if there are issues there.Good lock to you.
  3. Fletch81
    Fletch81 New Member
    9
    Apr 26, 2017
    i am not sure but for now ill have to get the car home its in the school parking lot. haha thanks
  4. Twisted_Metal
    26,200
    575
    I'm guessing it's an automatic transmission... Correct?
    The back drive linkage from the transmission to the column is probably worn or out of adjustment.
    Grab the collar on the steering column (right in front of the gauges) and twist it counter clockwise.
    That should get the column internals in the correct position to lock the wheel and allow the key to be removed.
    Good Luck!
    Soundwave likes this.
  5. Fletch81
    Fletch81 New Member
    9
    Apr 26, 2017
    ok thanks i hope that works ill try before i take it to my mechanic
  6. Fletch81
    Fletch81 New Member
    9
    Apr 26, 2017
    The collar won't budge from where its sitting and the key still will not come out.
  7. Fletch81
    Fletch81 New Member
    9
    Apr 26, 2017
    here are some images...
  8. Twisted_Metal
    26,200
    575
    If the key won't turn back to "Off"... There must be something jamming either the switch itself (screwed to top of column by the firewall) or the rack and sector pieces are messed up.
    The tilt column rack and sector kit is available as a HELP (Dorman) part #83211. (Under $10)
    For future reference: (Tilt version pictured.)
    Try this link for parts. ----> http://www.rockauto.com/catalog (Enter 83211 in the part search)
    Here's where they fit...
  9. Green hornet
    Green hornet Veteran Member
    1,467
    226
    Oct 11, 2015
    North Bay, CA
    Twisted is correct the rack is probably broken. I have changed a few over the years with this issue.
  10. Fletch81
    Fletch81 New Member
    9
    Apr 26, 2017
    Huh would the tilt still work if the rack is broken? Thanks for the help!
