81 Brake Master/Booster Combo on 80 model
Discussion in '1978 - 1981 Specific' started by ric28z, Feb 5, 2018.
  1. ric28z
    ric28z Member
    57
    Feb 12, 2012
    Newcastle NSW
    Hi all
    I think this should work but just wanted to check. Need a new master and booster but prefer the 81 style which has alloy master cylinder and is tilted to compensate for the angle of the booster mounted to the firewall.
    Both combos are a similar price but I just prefer the later setup compared to the earlier block of cast iron.
    Please let me your thoughts
  2. budro6968
    budro6968 Veteran Member
    2,709
    369
    Apr 2, 2016
    Jax Florida
    Probably will work. My Camaro is an 81 but is titled a 78. It has the old style M/C. I guess the proportioning Valve would have to match. Not sure though.
  3. larrylarry
    larrylarry Veteran Member
    1,531
    68
    Dec 22, 2011
    San Antonio Tx
    That’s what I have on my 78 but you have to use both the master & booster. The rear port on the master is for the front brakes FYI.
  4. CorkyE
    9,839
    314
    You have to buy or make new M/C to prop valve lines.
  5. ric28z
    ric28z Member
    57
    Feb 12, 2012
    Newcastle NSW
    Thanks guys, I thought it would work but just wanted to be sure, can make new brake lines no probs as I work in a brake/spare parts shop.
    Cheers
  6. br80z
    br80z Veteran Member
    511
    Apr 6, 2001
    Fuquay Varina, NC
    I used the booster and master cylinder from an 81 on my 80 z28, I also used the proportioning valve and brake lines from an 81, I just replaced everything at once.
