80Z Sparkplug cross threaded.
Discussion in 'Tips 'n' Tricks Topic' started by GBar80Z, Jul 26, 2017.
  1. GBar80Z
    GBar80Z New Member
    Jun 23, 2017
    I think I cross threaded one of my sparkplugs when I replaced them 20+ years ago when I was a kid and I just discovered it now that I'm starting to restore it. Is my head toast or can I fix the threads some how? Can a machine shop re-tap the threads?
  2. 70-camaro
    70-camaro Veteran Member
    1,071
    108
    Mar 25, 2010
    marietta ohio
    It can be fixed with a heli-coil. It is easy to do with the head off. The machine shop should be able to do this for you.
    GBar80Z likes this.
  3. CorkyE
    9,053
    173
    If the threads aren't in too bad of shape, you may be able to repair with a spark plug thread chaser tool, may even be able to rent it from AutoZone or Advance, etc. Do a Google search, you'll get a lot of info. Otherwise, it's best to go the helicoil route.
    GBar80Z likes this.
  4. Twisted_Metal
    25,460
    348
    Chase it.
    I did that with a plug on my old 305 that I got from a salvage yard in the 80s.
    My son is still using that engine and the cross-threaded plug hole has never caused a problem.
    You just have to be VERY careful you get the plug started in the correct set of threads the next time you change them.
    GBar80Z likes this.
  5. budro6968
    budro6968 Veteran Member
    1,602
    213
    Apr 2, 2016
    Jax Florida
    If it is a stock iron head you could find a cheap used one and use it if the threads are too bad.
    GBar80Z likes this.
