79 Z28 & 69 SS396
Discussion in 'Project Progress' started by HawkX66, Sep 20, 2017.
  1. HawkX66
    HawkX66 Member
    84
    21
    Sep 20, 2017
    MI/MA
    I appreciate the concern, but as long as they're flat on the floor they aren't going anywhere. I have better jack stands, but these were the ones I grabbed. After 40+ years of using similar ones I'd probably get killed if I changed to something else lol... Maybe it's the angle, but the car isn't overly high either.
  2. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    1,946
    37
    Feb 2, 2008
    SF
    Nice cars and welcome
    Are putting the vinyl top back on the 69 ?
    Mine has a vinyl top and I kind of want to remove it haha but can’t decide
  3. HawkX66
    HawkX66 Member
    84
    21
    Sep 20, 2017
    MI/MA
    Thanks. Yes, it's going back on. Without it, it'd be too much orange for me. I guess you either like it or you don't lol I actually went through a lot of trouble making a tool and taking measurements to put my trim studs back on. I like the look. Here's what it looked like from the factory, but I'm going day 2:
  4. HawkX66
    HawkX66 Member
    84
    21
    Sep 20, 2017
    MI/MA
    Yesterday was brakes day. I installed a new master cylinder and cleaned up the booster a little. I should have taken it off to do it right, but that'll be another day. For now, this will work. I started off trying to bleed the brakes with my new pneumatic bleeder and no fluid was flowing. I thought, wtf, new tool doesn't work. After trying my vacuum pump and then the pump the brakes method, I figured out it was the flex lines. All three were bad. Once I swapped those out it bled easily.
    A buddy of mine had a set of street slicks so I threw them on to see the fit. Once I put some air in the shocks they slid under. I think with some different off set wheels they'd sit under the 1/4 a little better. For those that notice.... Yes, they're on the wrong sides. I was just testing the fit... These are 275/60R15 M/T ETs.
