79 street/strip/corner carver
Discussion in 'Project Progress' started by SR79, Feb 21, 2008.
  1. SR79
    SR79 Veteran Member
    421
    Sep 14, 2005
    Carrollton/Sherman, TX
    Onward and upward, 2018 was coming fast and we needed a way to close a pretty significant gap to the front of the GTV. We've scoured tons of build pictures and had some ideas for a while on how to revise the front suspension to fit a proper coilover and make it much more effective with a redesigned lower arm, along with redesigning the upper arm mounts to cure some issues with the base geometry.
    Step 1: build a frame table
    Step 2: disassemble car
    Step 3: take a break to spot yourselves on Battle of the Builders
    Step 4: hack and slash
    Step 5: we will rebuild
    The march of progress
    Step 6: redesign upper mounts for a less aggressive camber gain and significantly lower roll center
    Step 7: mount coilovers (coilovers coming later..)
    Step 8: NASCAR swaybar!
    For better or worse, we're changing damn near everything. The car should be significantly stiffer, with a more compliant camber curve, and a vastly improved shock package front and rear to keep it all under control.
    I've also started making video updates on our progress -
    Part 1
    Part 2
    Part 3
    Just under 2 months til NOLA, we'll be ready - the question is, how much testing will we be able to do before then?
    G72Zed likes this.
  2. CorkyE
    9,716
    298
    Wow, quite impressive. :)
  3. John Wright
    14,391
    123
    Aug 9, 2002
    Rustburg, Va
    Oh man....this car has really come a long ways since I saw it last! Impressive work.
  4. woody80z28
    5,526
    40
    Sep 8, 2004
    walton, ny usa
    Every iteration of this car it keeps getting cooler! (Well maybe except when you put an auto in it briefly...haha) Pictures look great as always, just watched the videos too. Noticed you were a south paw welding. So that's like me driving in Australia. I was surprised how banging gears wrong handed was so much easier than staying in my lane.
    Seriously badass stuff. Inspiring you see you out there competing with a rubber nose set on KILL. Also kinda disappointing seeing how far mine will be from reliable if I really try to pound it hard. Mine won't be competitive, but I do hope it holds together when I throw it around.
    I'm surprised to see a carb with those kind of G's. You using a GoPro or TrackAddict to record G forces? And is the race pan mainly what you're doing for oil control? I don't want the expense of a dry sump but am considering an Accusump.
  5. SR79
    SR79 Veteran Member
    421
    Sep 14, 2005
    Thanks!
    Thanks, John - we've become somewhat obsessed over the years (just realized I started this thread TEN years ago!)
    Thanks Woody! We had fun with it as a drag car, too, but I love hanging corners with it. I'm a mix of lefty and righty depending on the task, but I can booger up some beads just as well with either. The things we've run into have come with getting pretty serious on massive tires, it was still a whole lot of fun before we went off the deep end..
    We've had good luck with the carb, only thing that really throws it for a loop is spinning it. For data, I have an Android tablet with an external GPS running SoloStorm for autocross, RaceChrono for track. That's been a huge help for my driving, along with being able to see how much harder we're pushing the car.
    We're using the Canton road race pan and a Moroso accumulator. After putting in the 421, we had oiling problems in right hand corners that necessitated the accumulator. Before that with the stock 400 block 377 we had no issues with the same pan. I'm not sure where the threshold would be on a stock pan, but in the long run it's fairly cheap insurance.
    John Wright likes this.
  6. z28cp
    z28cp Veteran Member
    339
    8
    Jan 16, 2009
    Bellevue, NE
    Car is looking better and better!
    You probably already know this, but... You should try to keep the coilovers as close to vertical as possible. The effective spring rate drops quickly as you start leaning them over. Mine are mounted to the outside of the front rollcage tube, with about 1/2" clearance between the tire and the spring. Bottom of the coilover out as far as possible on the lower arm, which it looks like you have covered.
  7. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Saw you and the car on TV last week running against the other red 2nd gen, wow is all I have to say that car is planted........................
  8. woody80z28
    5,526
    40
    Sep 8, 2004
    walton, ny usa
    I binge watched your channel on YouTube. I gotta quit screwing around with my Beretta and get the Camaro done! Haha
  9. simso
    simso Veteran Member
    221
    Jul 10, 1999
    Australia Perth WA
    Wow, what colour red is that.
    Steve
  10. SR79
    SR79 Veteran Member
    421
    Sep 14, 2005
    Definitely took that into consideration. We went as vertical as we could given the packaging constraints. The main focus was on pushing the lower mount out as far as possible to improve the motion ratio, which is has a bigger effect than the angle correction.
    Thanks! That was a blast, Cody in the other car is doing essentially the same changes so it will be fun to run against him again and see who got the formula correct, haha.
    Don't resist the V8 rumble!
    It's a color originally used on the PT Cruiser of all things called Salsa Red.
