78-79 hood scoop mod
Discussion in 'Tips 'n' Tricks Topic' started by Blue1979, Dec 3, 2011.
  1. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,525
    13
    Feb 11, 2009
    Kentucky
    according to hotrod magazine. It increases you 1/4 time by a tenth so. Might not be noticed but I'm sure it helps pull some cool air Into the engine. Especially when using the air induction seal ring and air cleaner.
  2. frankz
    frankz Veteran Member
    2,062
    Aug 24, 2009
    Illinois
    IIRC,noted guru Jim Mcfarland determined that a performance 350 engine requires 20sq. in. of intake area.How big is the opening on this hood?
  3. Racer1283
    Racer1283 Veteran Member Lifetime Gold Member
    467
    Jan 20, 2002
    Batavia, NY, USA
    I picked up 2 tenths at the track when I opened up my scoop. I made a sheet metal pan and used foam rubber to seal it against the hood. The problem I had was when I went to the 383 with the Victor Jr. and Doublepumper, I ran out of hood space, so I split the scoop and added 2 inches to the opening, without any increase in ET, but I had clearance and unless you really look close can't you tell it's not stock. If I had to do it again, I probably would have gotten a small diameter air cleaner and made a new air box.
    As far as water getting in the opening, a used some screen from a screen door and covered the opening. I never had problems with water getting in to the air cleaner.
    If I remember, the opening is something like 1 3/4 by 11 inches, but I may be wrong.
  4. Blu-By-U 79Z
    5,525
    13
    Feb 11, 2009
    Kentucky
    Its around 11 X 1.25 in.
  5. my24ktrat
    my24ktrat Veteran Member
    1,225
    Jul 5, 2007
    Roch., NY
    ...On my car I picked up 2-3 mph and a 10th , no rain issues, cars like it in cooler weather, nice cheap upgrade, DC :bowtie:
  6. earnhardtgm3
    earnhardtgm3 Veteran Member
    1,494
    14
    Dec 18, 2007
    Camaro Country,GA
    Here's mine and never had issues in rain, but cold weather makes it run like a scolded ape.Drilled holes in the metal cover.
  7. dioismyhero
    dioismyhero Veteran Member Gold Member
    382
    Nov 26, 2008
    siloam springs arkansas
    i cut mine out.. looks cool cause i can see a little chrome from the breather through it.. i never drive in the rain...
  8. marlin
    marlin Veteran Member
    242
    Oct 27, 2009
    Wantagh, NY
    dioismyhero awesome looking car!
  9. dioismyhero
    382
    Nov 26, 2008
    thanks alot!
  10. Blu-By-U 79Z
    5,525
    13
    Feb 11, 2009
    Kentucky
    Do you have any pictures of the bottom of your hood? Thanks and sweet ride.
