77 camaro 250ci inline restoration
Discussion in 'Camaro Questions' started by rezajahanshahi, Sep 19, 2010.
  1. rezajahanshahi
    rezajahanshahi Member
    82
    Dec 25, 2009
    iran
    any comments ??????
  2. rezajahanshahi
    82
    Dec 25, 2009
    iran
    Hi
    I need to know that how much distance is required between exhaust muffler and headers collector ?
    Engine is stock V 8 together with summit headers and 2.5 ‘’ dual exhaust with thrush glass pack mufflers and im going to use turn down pipes for the outlet .
  3. ls777z
    ls777z Veteran Member
    2,085
    Feb 19, 2000
    Clay,NY
    You could bolt the mufflers right to the collectors but don't plan on listening to your radio or your passengers while driving. And putting the exhaust pipes down you're going to blow up a lot of dust/dirt that will find it's way into your car. Moving the mufflers farther back will make the interior a liitle more "accoustically pleasing" as well as having the exhaust exit out the tail end of the car, where having them turned down shouldn't cause any issues. Some people have them exit just behind the doors but I've never had them like that so I can't tell you the pros/cons.
  4. rezajahanshahi
    82
    Dec 25, 2009
    iran
    Hi
    Im planning to buy cam shaft that I can use on street and strip .
    I have found following cams for my stock 350 engine with 4 mv Rochester.
    I need to know approximately how many horse power I will gain with each one?
    I don’t want to get max torque above red line .
    Please help
    http://www.summitracing.com/parts/sum-1065
    http://www.summitracing.com/parts/sum-1069
    http://www.summitracing.com/parts/sum-1787
    http://www.summitracing.com/parts/cca-12-105-3
    http://www.summitracing.com/parts/cca-12-230-2
  5. ls777z
    2,085
    Feb 19, 2000
    Clay,NY
    I like the first one. But if you're going with the 4.11 you'll need something that will pull into the 6000 range. I'm not sure what you have but 3.73's would be good with it.
  6. rezajahanshahi
    82
    Dec 25, 2009
    iran
    thanks
    also i like the first one so itd going to be .....
    :bowtie:
  7. rezajahanshahi
    82
    Dec 25, 2009
    iran
    Hi
    I want to increase the compress ratio of the engine I think its 8.5:1 and I need more than 9:1 for the mentioned camshaft .
    How I can increase the ratio ?
  8. rezajahanshahi
    82
    Dec 25, 2009
    iran
  9. rezajahanshahi
    82
    Dec 25, 2009
    iran
    hi
    i found out the ratio i have on rear end is :
    2.56:1 41,16
    :mad: :mad: :mad:
  10. ls777z
    2,085
    Feb 19, 2000
    Clay,NY
    You could change the head gaskets to some thinner ones (depending on what you have now) which will pick you up a little bit. The only other way is pull the heads, which you would have to do to change gaskets, and have them milled. Which is easier than replacing the pistons.
    Yes those gears aren't exactly for performance...unless you're going for top end speed.:p
