77 camaro 250ci inline restoration
Discussion in 'Camaro Questions' started by rezajahanshahi, Sep 19, 2010.
  1. rezajahanshahi
    rezajahanshahi Member
    82
    Dec 25, 2009
    iran
  2. rezajahanshahi
    82
    Dec 25, 2009
    iran
    Hi
    I have a question regarding intake manifold bolt pattern for square bore carburetors :
    I have 650 cfm holley double pumper carburetor 4150 part number and its square bore for installing it on stock 350 intake manifold I had to use carburetor adaptor now im looking to purchase performance intake manifold ( 2500 – 6500 rpm ) together with cam shaft and etc .
    If I buy square bore intake manifold do I need to use this adaptor ?
    Reason I ask this question is because if need to use adaptor I may face some hood clearance issue .
    Any suggestions for intake manifold ?
    Many thanks .
  3. ls777z
    ls777z Veteran Member
    2,084
    Feb 19, 2000
    Clay,NY
    If your Holley carb is a square bore (meaning all four throttle blades are the same size) you don't need the adapter for square bore intake.
  4. rezajahanshahi
    82
    Dec 25, 2009
    iran
    Hi
    I was lucky to find a stock clutch kit from 38 years ago in a friend warehouse
    Clutch disk diameter is 32 cm and its 4 pad graphite and I was told it was original for 1977 chevy trucks and blazer .
    Im running 3 speed Saginaw with stock flywheel .
    Before I purchase this kit I need to know 32 cm diameter clutch disk and pressure plate will fit to my 3 speed Saginaw tranny ?
    Do I need to change flywheel as well ?
    Many thanks
