74 Z28 radiator fan
Discussion in 'Camaro Questions' started by Jeep43, Jan 9, 2018.
  1. Jeep43
    Jeep43 Veteran Member
    1,083
    18
    Mar 30, 1999
    Connecticut
    My mostly original 74 Z came with a fixed flex type fan (sheetmetal blades riveted to a main hub and bolted to the water pump with an aluminum spacer). I presume this is not the factory type and assume that there was a clutch fan there from the factory.
    What should my non-A/C 4 speed car (if that at all matters) have for a cooling fan??
  2. ronzz572
    1,903
    49
    Feb 8, 2007
    imperial pa
    The 74 z28 uses a standard flex style fan with a aluminum spacer with or without A/C. Post some pictures to confirm what you have?
  3. Jeep43
    1,083
    18
    Mar 30, 1999
    Connecticut
    Dragged it out. Its marked 330533 so I guess its original.
    Any worry of this type of fan construction coming apart?? During my searches I found that a similar style (but larger diameter) on 70's/80's trucks # 336032 prompted a letter somewhat recently from GM to advise discontinuation of use.
  4. Zstar
    Zstar Veteran Member
    1,379
    286
    Mar 23, 2014
    Ocala, Florida
    My 73 came the same way, no problems.
  5. 74Z28GC3
    74Z28GC3 Veteran Member
    1,558
    18
    Sep 1, 2000
    North Pole, Alaska
  6. Jeep43
    1,083
    18
    Mar 30, 1999
    Connecticut
    So my 330533 needs to be restored. Right now its mostly black but the black on the tips of the flex blades is bare stainless, its weathered and has some minor rust on the hub/rivets. I presume a good coat of semigloss over the whole thing is the right finish?
    Any tips to strip the old paint? I don't want to throw it in the blaster and get grit caught between the sheetmetal assembly? Perhaps just aircraft stripper to get the paint off followed by a bath in evaporust to remove any minor rust on the rivets/hub then shoot it?
  7. 70 SS/L78
    2,572
    62
    May 5, 2005
    Rockford, MN
    I would think paint stripper should do it. I had my fan blade powder coated so the paint finish would hold up better on the blades.
  8. COPO
    16,778
    360
    I used spray can paint remover.
  9. Jeep43
    1,083
    18
    Mar 30, 1999
    Connecticut
    45 mins with aerosol aircraft remover didn't phase it. Will have to rethink this....
  10. bodymanbill
    bodymanbill Veteran Member
    998
    281
    Feb 1, 2007
    South Park Pa
    image.jpg Just put it in the blast cabinet, i did mine on my 73 that way with no issues
