74 Z28 battery
Discussion in '1974 Specific' started by Jeep43, Jan 31, 2018.
  1. Jeep43
    Jeep43 Veteran Member
    1,107
    21
    Mar 30, 1999
    Connecticut
    What should my 74 Z have come with for a battery and what brand? Do they make a topper that is correct or one close?? If so, which one?
    I need a new battery and would like to get a brand and size that fits under the best option that is out there.
  2. COPO
    16,864
    371
    I'm using this battery in my 70 Z28. 10" x 6.25"
    [​IMG]Battery by C O P O, on Flickr
  3. 70lt1z28
    2,637
    392
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Originals would have been Delco R89S standard battery or R89W with optional heavy duty battery.
  4. Jeep43
    1,107
    21
    Mar 30, 1999
    Connecticut
    So this style is correct.
    How can I determine if my car came with a R89S or W? I unfortunately do not have a build sheet. Was the HD battery paired with other equipment such as A/C or was it an independent option? My car is a non A/C car but has a 26" radiator (but that could have been added later too).
  5. 70lt1z28
    2,637
    392
    Oct 3, 1999
    I believe but do not know for sure that the HD battery was a separate option and the only way to fully determine if you had it was a build sheet. No changes in the cable or battery mount system can be seen.
    It MAY have been included with big block cars or maybe for cars destined for Canada (cold weather). The posts are a little fuzzy on this.
  6. Jeep43
    1,107
    21
    Mar 30, 1999
    Connecticut
    Ok thanks,
    I'm not hung up on it being exact but figured if I need to get a battery anyway, why not choose one that works well with the right topper.
  7. CamaroNmotion
    CamaroNmotion Veteran Member
    312
    Jan 8, 2006
    Buffalo, NY
    Style is correct however 74's did not have have red color on caps.
