74 Camaro Z28
Discussion in '1974 Specific' started by STLCamaro, Sep 12, 2014.
  1. zfool
    zfool Veteran Member
    527
    8
    May 19, 2014
    Rochester, MN
    Is yours welded Pilot? I think Ive seen another late production car with a welded tab.
  2. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,024
    16
    Oct 8, 2009
    Emerald Isle , NC
    Yes.....that's the same as mine....the three ridges with inspection hole.. During Sean's 74 Z28 restoration thread , he took the engine out, and he sent me a picture close up of the timing cover....I was curious...his was the same, welded on. His car was HEI series too. Our engines looked the same far as I could tell. Except his was auto trans car. Both tab and cover were one piece painted orange pressed steel unit .
    Maybe Ron and George can chime in.
  3. zfool
    527
    8
    May 19, 2014
    Rochester, MN
    Once we got access to the front of the engine to get a look at the tab I was sorta disappointed because I'd been hearing about the bolt on tab( this welded one I cannot find in the parts books). I saw it has the 8" torsional damper and expected the bolt on. I think I like this better, one more controversial part that doesn't exist or shouldn't or can't be there right lol.
    I think the list is up to about 140 part numbers for sp. Hi/perf 350 parts.
  4. Z28PILOT
    2,024
    16
    Oct 8, 2009
    Emerald Isle , NC
    Not sure about 1973 engines....but
    My early 74 corvette motor LS4 has never been out of the car or torn down ...knock on wood...I just tuned her up this summer and that motor has a orange pressed steel cover with welded on tab with hole too :)
  5. ronzz572
    1,903
    49
    Feb 8, 2007
    imperial pa
    My car has the welded front cover. It appears to have a 74 date code stamped in it too. I will get a few pictures to post.
  6. 74Z28GC3
    74Z28GC3 Veteran Member
    1,561
    19
    Sep 1, 2000
    North Pole, Alaska
    I checked my timing cover and it has a welded tab too. My 74 Z28 was builded in September 73 and came original with a point distributor.
    George
  7. zfool
    527
    8
    May 19, 2014
    Rochester, MN
    I didn't have time to look for a PN or date when we worked on it last. I'll look this weekend if I get a chance.
  8. Jonesy
    Jonesy Veteran Member
    430
    Jun 7, 2008
    Minnesota
    My car has the bolt on and when I took it off it still had what remained of the factory sticker with part # stuck between it and the cover. It definitely came that way from the factory. 03C build and its a 4 speed.
    I know you can still find these timing tabs out there NOS.
  9. twozs
    twozs Veteran Member
    8,792
    165
    Aug 5, 1999
    hopewell jct ny
    My 73 has a welded one .
  10. zfool
    527
    8
    May 19, 2014
    Rochester, MN
    So the absolutes for these car the big bumpers, grey dash bezel and the dual snorkel air box :)
