74 Camaro Z28
Discussion in '1974 Specific' started by STLCamaro, Sep 12, 2014.
  1. 74 Z28 dude
    74 Z28 dude Veteran Member
    269
    Mar 23, 2005
    North Bend, WA USA
    Hey George,
    Correct me if I'm wrong, but the EGR valve should be MT 7040299. I haven't been able to find one for over 10 years. Anyone know of one for sale?
  2. 74Z28GC3
    74Z28GC3 Veteran Member
    1,522
    17
    Sep 1, 2000
    North Pole, Alaska
    Yes, the MT 7040299 EGR valve is for a 4 speed 74 Z28. The EGR valve I listed in my post KM 7041413 is for an TH400 which is what originally came on my 74 Z28. Both of these EGR's are very hard to find. I will be on the look out for a 4 speed EGR valve for you.
    George
  3. 74 Z28 dude
    269
    Mar 23, 2005
    North Bend, WA USA
    Thanks to George! He sent me a note telling me of the correct EGR valve for my 4 speed car on Ebay, and I bought it right away. Thanks again, George!! I had stopped looking and thought I would never find one.
  4. STLCamaro
    STLCamaro New Member
    Sep 3, 2014
    St. Louis, MO
    When the previous owner went thru the engine he replaced all the tin with chrome. I don't have any of the original covers. So a regular SB oil pan works with the windage tray?
  5. ronzz572
    1,874
    45
    Feb 8, 2007
    imperial pa
    No a regular pan will not work. You will need the oil pan for the windage tray. I have my original off my motor. I will try to get some pictures posted.
  6. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,022
    15
    Oct 8, 2009
    Emerald Isle , NC
    The balancer was the 8" wheel. Or HiPer . This will require the correct timing cover . I'm guessing your missing this cover too . It was painted orange with the welded on tab . You might find one on eBay ..I've seen them on there.
    If you need the aluminum valve covers.....get the style with screw on chrome fill cap .....not the the ones with the rubber stopper cap. I'd look for an original pair if I were you, the repop is not so great , diff material, too shiney , poor sealing amoung other defects.:)
  7. zfool
    zfool Veteran Member
    522
    May 19, 2014
    Rochester, MN
    Sounds like a fun project, they are very unique cars with generally pretty unique owners. Getting it back 100% will be a challenge but as you can see these guys look for what each other needs and help out where they can. So many of these cars got dressed up after 72 because of the hyd cam, iron Intake and quadrajet. The reality was they weren't that much slower to begin with. In the GM parts books they actually make a note about changing the hyd cam and lifters to the solid and to make the lash adjustments accordingly. Post some pics and good luck.
  8. 74Z28GC3
    1,522
    17
    Sep 1, 2000
    North Pole, Alaska
    ronzz572 wanted me to post these pictures of his 74 Z28 original pan.
    George
  9. ronzz572
    1,874
    45
    Feb 8, 2007
    imperial pa
  10. Jonesy
    Jonesy Veteran Member
    428
    Jun 7, 2008
    Minnesota
    My 1974 Z28 did not have this type of timing cover on it. The timing tab was separate and it used 2 bolts from the cover to mount it.
