73 Nova and Camaro Rearends
Discussion in 'Transmission & Driveline Topics' started by moemills, Sep 12, 2006.
  1. moemills
    moemills Veteran Member
    138
    Feb 25, 2002
    Laguna Niguel, CA. USA
    Does anyone know off the top of their heads if these rearends are interchangeable? Both are leaf spring and preliminary measurements look very close.
  2. Rowdy79'
    Rowdy79' Member
    64
    Jun 19, 2006
    Illinois
    Everything i've been told is yes. I've never tried it myself but i have been looking for a new rear end and everything i have found matches up the same.
  3. onovakind67
    onovakind67 Veteran Member
    4,654
    Jul 8, 2001
    Fairfield, CA
    You mean a 73 Nova and a 73 Camaro?
  4. moemills
    138
    Feb 25, 2002
    Yes, I mean a 73 Nova and a 73 camaro ... thanks.
  5. onovakind67
    4,654
    Jul 8, 2001
    Fairfield, CA
    The 73 Camaro rear end is wider and the perches have different spacing.
  6. Kyle C
    Kyle C Member
    77
    Sep 24, 2002
    Sanford, NC
    73 Nova rear will bolt directly in a 1st gen fbody.
  7. big gear head
    big gear head Veteran Member
    5,893
    19
    Jul 30, 2001
    Central City, Ky.
    That is correct. The '67 to '69 Camaro and '68 to '75 Nova rear ends are the same width (60 inches) and the spring perches are in the same location (42 1/2 inches center to center) and will interchange. The '70 to '81 Camaro rear ends are 61 inches wide and the spring perches are 45 1/4 inches center to center.
  8. BobB
    BobB Veteran Member Lifetime Gold Member
    1,873
    May 10, 2000
    USA
    75-79 Nova interchanges with 70-81 Camaro. 68-74 Nova and 67-69 Camaro interchange.
  9. onovakind67
    4,654
    Jul 8, 2001
    Fairfield, CA
    The 75-79 Nova rears are the same size as the 68-74 Nova rears. Here's some info on those rear ends:
    http://novaresource.org/axle.htm
  10. big gear head
    5,893
    19
    Jul 30, 2001
    Central City, Ky.
    I have run into a few '76 and later Novas with the wider 8.5 in them. I don't know why some of them have the wider rear end. You need to check them before you go to the trouble of taking one out.
