73-74 Dash Bezel Grey Match
Discussion in 'Interior Restoration' started by zfool, Jan 30, 2018.
  1. zfool
    zfool Veteran Member
    527
    8
    May 19, 2014
    Rochester, MN
    Anyone know what color is a match from SEM or other?
  2. 1971CamaroGuy
    3,650
    131
    Oct 31, 2004
    Arkansas
    if your not able to figure it out you can take the bezel to a auto paint supplier and they can scan it and mix you something up.
  3. zfool
    527
    8
    May 19, 2014
    Rochester, MN
    I would but the bezel was repainted 30 years ago the wrong color. Unfortunately the guy took it off the car painted it and stuck it in a box (which preserved it from cracking) when he found a wood grain LT bezel and went with it instead.
  4. xten
    xten Veteran Member
    2,084
    1,015
    Sep 24, 2014
    Pittsburgh, Pa.
    Just a heads up, if you go to a store to look at the color of the SEM can lids (which is supposed to be the sprayed out color), they're not very accurate. Their color chart would give you a better idea. Seriously doubt if mine is original, but my bezel is black. I'll betcha bodymanbill would know.
  5. twozs
    twozs Veteran Member
    8,813
    165
    Aug 5, 1999
    hopewell jct ny
    74 dash grey.jpg i cant vouch for this car but it looks as all other 73-4s i've seen .
    zfool likes this.
  6. 74Z28GC3
    74Z28GC3 Veteran Member
    1,578
    22
    Sep 1, 2000
    North Pole, Alaska
    Zfool, You may want to contact Pete at Fbodywarehouse and ask him about a good SEM color to use. They sell the SEM Interior paints and re-dye parts for customers.
    twozs, His picture of the bezel is the correct color of how they look in 73’s & 74’s dashes. Mine in my 74 Z28 came original like that too.
    zfool likes this.
  7. xten
    xten Veteran Member
    2,084
    1,015
    Sep 24, 2014
    Pittsburgh, Pa.
    Is there supposed to be a chrome or silver edge around the bezel and gauges, or does it remain black?
  8. 1971CamaroGuy
    3,650
    131
    Oct 31, 2004
    Arkansas
    Pretty sure it's black, the early one's and some deluxe woodgrain had chrome edges
  9. 74Z28GC3
    1,578
    22
    Sep 1, 2000
    North Pole, Alaska
    Black and chrome edge description just like 1971camaroguy stated above.
  10. zfool
    527
    8
    May 19, 2014
    Rochester, MN
    I'll see what he says. Thanks
