'72--copper contacts behind turn signal mechanism??
Discussion in 'Electrical Systems' started by Bossman, Oct 16, 2017.
  1. Bossman
    Bossman New Member
    24
    May 28, 2017
    So while I had to replace the turn signal mechanism and get the wheel lock switch out, I thrashed the two tiny copper contacts behind the turn signal switch. What did they do because everything I'm trying to get to work, is working now?
  2. dale68z
    dale68z Veteran Member
    1,303
    May 14, 2009
    Glendale Arizona
    Are you talking about the key in cylinder reminder contacts. It makes the horn relay buzz when the door is opened and the key is in the ignition
  3. Bossman
    Bossman New Member
    24
    May 28, 2017
    Hmmm.. That sounds as good an explanation as any. So if it's messed up it don't really matter in this situation. Thanks a bunch for the help!!!
