71 pro touring/resto mod project
Discussion in 'Project Progress' started by Seventy1ProTour, Nov 22, 2017.
  1. Seventy1ProTour
    Seventy1ProTour Member
    67
    14
    Oct 18, 2017
    Huntersville NC
    I figured I'd start a thread to showcase some of the things I've been updating on the car. I bought this 71' in great condition with alot of the parts already upgraded, but it's nowhere near what I'm visioning. So let's start...
    This 71' is equipped with hotchkis front springs/rear leafs, hotchkis rear sway, handle bars, 4 pt cage, custom 2G bar, sub frame connectors and tubular upper and lower arms.
    Motor: Oval track crate 355ci, comp cam, aluminum heads, forged JE Pistons, forged crank, Holley ultra 650, single plane vic jr., longtubes, x pipe, flowmasters.
    Trans: th350 with some built components.
    Stock rear.
    Plans:
    Front wilwood or c5 brakes, rear disks.
    Wheels/tires
    Interior junk
    Better seatbelts
    Down the road...LS swap.
    Stay tuned.
  2. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Today I test fit some bullet mirrors I acquired. Need to paint match but I like em.
    Also test fit some wheels, I will give details on the setup once I get everything ironed out.
  3. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Front and rear, there are existing adaptors so the fitment isn't ready yet. Will probably run 20mm front and rear as the Vette wheels currently run larger adaptors. XXR531
  4. dave@ztech
    1,483
    182
    Mar 27, 2016
    NY
    Nice car, looks like you are building it to drive and enjoy it!!
  5. Turbo70Camaro
    2,134
    112
    Jan 7, 2005
    so cal
    Nice wheels looks like the rears gonna fit better then your current setup ( not tucked in) unless the angle of the picture is deceiving. Bullet mirrors the way to go also, great car next one for me will be something like your setup.
  6. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Mirrors painted and installed
  7. bigkat_83
    bigkat_83 Member
    30
    8
    Dec 7, 2014
    Bogart ga
  8. bigkat_83
    bigkat_83 Member
    30
    8
    Dec 7, 2014
    Bogart ga
    Nice car! Lets see some more pictures of the hood.
    I think I saw this at the GoodGuys show at CMS a couple of years ago.
  9. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Hmm, I'll ask previous owner if he had it out there.. was that 2013?
  10. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Got some brake updates.
    I picked up a set of 2014 Camaro SS brembos, came with rotors and pads which I used a micrometer to check discard thickness. $300/all 4 corners.
    Next will be FlynBye rear brackets, stainless lines, and bigbrakeupgrade front brembo partial spindles.
    Cant wait.
