71 grill question
Discussion in '1970 - 1973 Specific' started by elzee, Feb 6, 2012.
  1. elzee
    elzee New Member
    Feb 5, 2012
    WI
    My 71 camaro z28 currently has the wide spaced grill with the tighter spaced slots about half way down and the hood pull slot. I need to know if this is the correct grill or is it supposed to have the tight spaced grill instead. It is a single piece grill not two if that helps. Thanks
  2. COPO
    16,334
    264
    Welcome aboard. Pics please.
    71 RS grille
    71 non RS grille
  3. elzee
    elzee New Member
    Feb 5, 2012
    WI
    the first one is different than mine, mine is one piece and there has to be a hole for the hood pull to go through although it is long enough to be pulled from the outside. I should get a pic up. But that is the tight pattern I meant, what years used the tight pattern?
  4. twozs
    twozs Veteran Member
    8,671
    130
    Aug 5, 1999
    hopewell jct ny
    70 - 71 small squares 72 - 73 bigger square pattern
