'70 only thread
Discussion in 'Original Drivetrain Topic' started by Kregb, Feb 25, 2010.
  1. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    See post #16 (http://www.nastyz28.com/forum/showpost.php?p=1931017&postcount=16)
  2. 70ZL3
    70ZL3 Veteran Member
    234
    Jan 27, 2003
    Emporia Kansas
    Hurst shifter handle, shifter mounting plate for muncies,L34, Shadow Gray paint.
  3. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    I'm like 99.9% certain that the 7433 shift handle for Hurst was a '70-71 item (the only two years for Hurst in 2nd gen Camaros) same goes for the mounting plate - for the same reason.
  4. 4buckeyes
    4buckeyes Member
    30
    Feb 6, 2010
    columbus,ohio
    1970 Body color
    1970 was the the only year Camaro Gold exterior body color paint was offered.
    later,
    2nd Gen.Camaro's Rule:cool:
  5. White81Z
    White81Z Veteran Member
    1,174
    Nov 17, 2004
    NY
    Actually code 53 was used in 1970, 71, 72 and 74. It was called Camaro Gold in 1970, Placer Gold in 71 and 72 and Light Gold in 74.
    In my opinion this thread as been beat up.
    Rick H.
  6. Dave Nelson
    3,675
    998
    Dec 19, 2003
    Vineland N.J USA
  7. fmarullo
    fmarullo Veteran Member
    400
    Mar 29, 2007
    Austin Texas
    Joe,
    The 0.01 saved you...
    Shifter handle:
    7433 (70)
    7945 (71)
    I'm 100% :)
  8. 70ZL3
    234
    Jan 27, 2003
    Emporia Kansas
    70 only mounting plate on left, 71-73 right
    70 camaro muncies used 584 tailhousing, 71-73 had 764 tailhousing
    Mounting holes are in different locations
    70 mounting plate will not bolt to 764 tailhousings
    71-73 mounting plate holes lines up with 764 tailhousings
    This plate can also be used on Super T10
    70 camaro only plate on 70 only 584 tailhousing
    http://www.nastyz28.com/forum/archive/index.php/t-80066.html
  9. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    Interesting - I'm showing that #7945 was installed on '70-71 Firebird/TA's with no console (as opposed to #7244 which would have been '70-71 Firebird/TA with console & '72-78 Firebird/TA with or without console). that's from Pete Serio who is "the Man" when it comes to Hurst shifters.
    Just for clarification (and not to challenge for the sake of challenging:happy:) On what do you base your assertion? Do you have a photo of a 7945?
  10. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    I stand corrected:D. I'd totally forgotten about the tail shaft housing change over for '71 so my logic above on the mounting plate was faulty.
