'70 LT-1 Valve Covers
Discussion in '1970 - 1973 Specific' started by ThomasD., Sep 11, 2017.
  1. COPO
    16,518
    301
    Yes, with these roller tip rockers.
  2. 70lt1z28
    2,238
    317
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Mark, what actually hits the dippers? Is it the Comp Cams rocker or the polylocks? Would you need the double extra thick gasket if you ran the stock nuts with the better rockers?
  3. COPO
    16,518
    301
    If your running with the gasket I showed with polylocks then the top edges of the polylocks will hit the edges of the drippers, not the roller tip rockers. If you use
    stock nuts then nothing should hit. When I had the solid cam I used stock nuts with the Comp roller tip rockers along with those thick
    gaskets and nothing rubbed. I did not try using the stock rocker nuts with the roller cam with the single gasket I showed above.
    I'm using polylocks with my roller cam and had to knock off my drippers. The covers were not worth saving anyways, plus I have a new
    set I bought in Princeton NJ from GM when my wife worked there for 1.5 yrs. GM Parts in Oshawa wanted $250 each for the covers and in NJ GM wanted $250 for both.
    When you go with the thicker gasket the stock valve cover bolts are too short and you'll have to use studs with nuts.
    When I get to use the new covers I'll have to double up on the gasket.
    I know a guys with a roller 302 in his 69 RS Z/28 and that's what he's doing
    with no leaks.
    Short Polylocks
  4. COPO
    16,518
    301
    Don't use Photobucket cause your pics won't show up.
  5. ThomasD.
    ThomasD. Veteran Member Lifetime Gold Member
    218
    Feb 23, 2010
    Fairbanks, Alaska
    Ok, I'm liking the 3/8" spacer. Never doubled up on gaskets before so which gaskets would be best on either side of this spacer ? Just regular or the metal core?
  6. COPO
    16,518
    301
    If your setting solid lifters and popping off the covers
    a few times/yr, then get the gaskets with the metal
    in between. I find the singles get mashed in no time.
  7. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
    They are solid lifters so will be occasional adjustments. Better get longer studs for the T handles. Has anybody actually used these spacers?
  8. 70ZED
    70ZED Veteran Member Gold Member
    275
    12
    Jun 21, 2010
    Calgary, Alberta Canada
    I like those shim plates. I'm running full roller rockers so maybe my LT1 covers can fit using those.
  9. BARNFIND
    BARNFIND Veteran Member Lifetime Gold Member
    309
    Oct 20, 2007
    GPS WENT DEAD...LOST
    With the 1 inch ones you can usually run Stud Girdles if you remove the sheet metal box under the breather and PVC valve. You don't really need the boxes, aftermarket valve covers never have them.
