'70 LT-1 Valve Covers
Discussion in '1970 - 1973 Specific' started by ThomasD., Sep 11, 2017.
  1. ThomasD.
    ThomasD. Veteran Member Lifetime Gold Member
    218
    Feb 23, 2010
    Fairbanks, Alaska
    My original covers are really pitted through and the new roller tip rockers would require the removal of the little splash tabs on the inside. Not going to modify the originals. Any one know of any similar looking after market covers made? Really like the original finned look but I'm not finding any after market.
  2. wnmech
    wnmech Veteran Member
    766
    42
    Jul 20, 2014
    grand prairie tx.
  3. COPO
    16,319
    257
    Find the thickest gasket and double it in height and seal them together for the extra height. You can get that hole welded up with aluminum from your local welders.
  4. 70ZED
    70ZED Veteran Member Gold Member
    270
    12
    Jun 21, 2010
    Calgary, Alberta Canada
    FelPro make the thick gaskets too and they are quality
  5. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
    This guy welds aluminum air boats for a living. Said he stopped because the casting was so porous that he was afraid he'd burn right through it.
  6. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
  7. wnmech
    766
    42
    Jul 20, 2014
    grand prairie tx.
    Yes they are stock height. Pretty much a exact reproduction of the originals except they have a smoother finish and a semi gloss shine.
  8. COPO
    16,319
    257
    I'm sure JB Weld would seal the hole too.
  9. COPO
    16,319
    257
    Not thick enough if you have short lock nuts but will clear roller tip rockets as I have also. I'm using Felpro 1604 with Steel Core center valve cover gaskets.
  10. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
    And your using the stock LT-1 covers with the splash tabs?
