'70 LT-1 EXHAUST MANIFOLDS
Discussion in 'Engine Topic' started by ThomasD., Nov 21, 2017.
  1. ThomasD.
    ThomasD. Veteran Member Lifetime Gold Member
    218
    Feb 23, 2010
    Fairbanks, Alaska
  2. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
    Ignorance on my part. I understand now that it was an operational system at one time. Since none of the AIS equipment was left on our LT1, I assumed it wasn't originally installed or required. Guess since inspections for registration weren't required in the '70's that removing all the AIR, AIS, CSS, etc. equipment was no big deal. Something new learned every day.
  3. COPO
    16,456
    290
    All 70 Z28's got the AIR pump/tubes. The 1st thing guys did when they received the cars was
    remove the smog and pitch it in the garbage and install headers.
  4. Twisted_Metal
    25,916
    488
    The AIR holes already have plugs in them.
    I don't think you need to worry about the tubes at all.
    If it's just for engine break-in... Bolt 'em on and fire it up!
  5. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
    Kinda thinking that. Except that they are in need of a good media blasting session to get some of the years of rust scale off, just to get a set of gaskets to seal. Wondering if the media blasting will damage the tubes at all anyway.
  6. Twisted_Metal
    25,916
    488
    Slip pieces of vacuum hose over the tubes when you media blast... It will protect them.
  7. ThomasD.
    218
    Feb 23, 2010
    Fairbanks, Alaska
    Great idea. Thanx
  8. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    Might be simpler and cheaper to throw a cheap set of headers on there. I’d bet that you could find a set cheap on Craigslist...even in Fairbanks ;):D
  9. ronzz572
    1,853
    44
    Feb 8, 2007
    imperial pa
    I was thinking the same thing. But Joe beat me to it.
  10. 70lt1z28
    2,117
    274
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Whats the consensus on the repop manifolds? They look decent to me. The date codes are stuck on E 28 8. what are the differences other than the dates from OEM?
