70 detail ?
Discussion in '1970 - 1973 Specific' started by 67johnny, Oct 20, 2017.
  1. 67johnny
    67johnny Member
    70
    Apr 14, 2016
    vancouver
    Hey all.
    Tried to get an answer to this one over in the body restoration section but it may do better here.
    I am trying to find out if the bolts that attach the outer fender to the inner fender
    (at the wheel well opening) come with a capture flat washer and the pointed or flat tipped 5/16 bolt on my 70 project.
    They are very visible and am thinking I would like to get this correct :)
    Thanks.
  2. COPO
    16,066
    201
    No washer than can spin. The bolt head is wide enough that a washer isn’t needed and the end is pointed.
    FlaJunkie likes this.
  3. 70lt1z28
    1,583
    176
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Its a flanged bolt head with a pointed end. AMK B-12500. GM PN 3960314
  4. restore-z28
    restore-z28 Veteran Member
    276
    28
    Jul 4, 2010
    Vancouver, BC
    Both post above are correct, it's a flanged bolt head. There are correct bolt kits available for both exterior and interior if you need to correct more of the hardware issues. I see you are in Vancouver, where are you located?
  5. CamarosRus
    CamarosRus Veteran Member
    As a added note.....The plating is Manganese Phosphate in my opinion
    Preserve your fastener finish with Fluid Film, Boe-Shield or LPS 3
    Dave, aka LTiZ28 your pics/post is terrific
  6. 67johnny
    67johnny Member
    70
    Apr 14, 2016
    vancouver
    Thanks for all the replys!
    Chuck > I did notice that there were a couple of options out there to re-phosphate fasteners.
    Also noticed that many of those methods obtain a distinctly different look.
    Looks like these guys addressed that in other ways > http://www.eastwood.com/ew-zinc-phosphate-aerosol-12-oz.html
    Will look into the variations in color the phosphating leaves behind for sure!
  7. FlaJunkie
    5,797
    55
    Mar 24, 2001
    Rockledge, Florida
    CamarosRus likes this.
  8. CamarosRus
    Phosphating small quantities of fasteners, brakets pcs NOT hard or expensive to do your self
    however the prep stage is important to have glassbeading or shot blasting machine available
  9. COPO
    16,066
    201
    I just came from Victoria and Vancouver BC. Where are you in Vancouver? I’d like to drop by the next time I’m in town to see your work.
  10. restore-z28
    276
    28
    Jul 4, 2010
    Vancouver, BC
    A couple of pics would be nice, maybe post a few shots of your car.
