70 Camaro front end work on 77 Camaro?
Discussion in 'Camaro Questions' started by 77Camaro77, Dec 17, 2010.
  1. 77Camaro77
    77Camaro77 New Member
    Dec 16, 2010
    washington
    I have a 77 camaro and want to put a 70 camaro front end on it. does anyone know how to do it? What will need to be changed out does the core support need to be changed and will i run into any problems?
    :bowtie:
  2. Rich Schmidt
    Rich Schmidt Veteran Member
    4,198
    30
    Mar 27, 2010
    Denville NJ
    The nose bolts right to the firewall of the car. The core support is different. I did the job on my 79 using a 74 core support and had to cut a lot of metal off the areas around the bottom of the radiator. I just got a new core supports so I can redo the job the right way. The bumper brackets also bolt to the core support and dont work with the later support.
  3. flowjoe
    7,956
    23
    Feb 7, 2006
    SoCal
    A '79 core support is definitely different from a '70-73 but I think a '77 is the same as the fenders are the same. DBL check me though before proceeding
  4. al8apex
    al8apex Veteran Member
    3,916
    Mar 11, 2005
    scottsdale, az
    the inner fenders for the 70-73 are one design, I believe that the 74-77 is another design and the 78-up another. Assuming the core supports are different as well, the 75 & up sub frame is different
  5. al8apex
    3,916
    Mar 11, 2005
    scottsdale, az
  6. GOLF72
    GOLF72 Veteran Member
    2,187
    Jan 11, 2010
    CORONA, CA
    I have a 76. It was fairly easy. Everything bolted up nicely. You do need to cut the horns to make lower valance fit. You need to weld the bumper support arms from top of support. I did away with them and made a plastic grille where the split bumpers would cover. I do not have a pic of that to show you. You need a 70-73 hood latch as well, plus headlight assembly and parking light assembly.
  7. al8apex
    3,916
    Mar 11, 2005
    scottsdale, az
    I have a perfect front bumper for you ... :)
  8. 5spd540
    12,343
    12
    Sep 19, 2009
    Guyton, GA
    I want to do a big bumper car next and put a 70-73 front end on one
  9. oslotaxi
    oslotaxi Member
    32
    Sep 14, 2009
    norway
    buy yourself a 70-73 instead !!
  10. Rich Schmidt
    4,198
    30
    Mar 27, 2010
    Denville NJ
    Just in case somebody in some far away corner of the planet hasnt met "Frankie" yet,here he is. Frankie was born a 79 but likes to play dress up with his bro's 73 parts.
    Frankie talks too. It may take a while for the video to load.,but if it loads you can here Frankie's 408 smallblock.
    Click on the pic to hear Frankie talk!
