70 Build Sheet questions - PIC LINK
Discussion in '1970 - 1973 Specific' started by Citrus70, Sep 12, 2012.
  1. Citrus70
    Citrus70 Veteran Member
    616
    Sep 3, 2012
    SW Ohio
    OK, got my build sheet up on my website. Mine is a SS but nothing on there that shows it is? Am I missing something? Have my cowl tag up also.
    I am not seeing some codes that show this car out to be an SS F41 or Z27 codes?
    see site pics... http://mycarisnice.com/camaro350ss/camaro350ss.htm
  2. bkmont
    bkmont Veteran Member
    981
    22
    Nov 14, 2010
    Pensacola, Florida
    Sweet! I wish I could have found my build sheet.:bowtie:
  3. Gary S
    21,082
    307
    Check the VIN on that build sheet and the VIN on your car. If they match, the car is not an SS equipped car. That build sheet shows the L65 engine which was not available on the SS.
  4. spons
    spons Veteran Member Lifetime Gold Member
    427
    Mar 21, 2010
    Indy
    That's not your car's build sheet. My car also had another car's build sheet in it.
  5. ddc456
    ddc456 Veteran Member
    490
    Oct 11, 2010
    Oregon
    yeah the build sheet says L65 w/ 2bbrl carb. yeah, make sure the vin#s match....my dads 70 Z28 had a build sheet behind the back seat but it was for the car behind his on the assembly line. we were lucky to find another on top of the gas tank...so check there as well.
  6. Citrus70
    616
    Sep 3, 2012
    SW Ohio
    Nope vins don't match from car and this build sheet. Damn this means it better be on top of the gas tank or I don't have a sheet. This shows a L65 what was this sheet too? Did they build diff cars at that plant at the same time?
  7. ddc456
    490
    Oct 11, 2010
    Oregon
    yep they built all types of camaros at the same time. this is the very same thing that happened to my dads march built Z.....hurry look on top of the gas tank!!!
  8. Gary S
    21,082
    307
    Yes, Van Nuys built Camaro, Chevelle, and Monte Carlo on the same assembly line in 1970. I found a 1970 Monte Carlo build sheet in a 1970 Camaro. Both were built the same day.
  9. spons
    427
    Mar 21, 2010
    Indy
    The first seven digits of the VIN should be 124870L for a Camaro.
    136370L is a Chevelle.
  10. Citrus70
    616
    Sep 3, 2012
    SW Ohio
    Jeesh, they can't get simple paper work to the correct cars along the line? ha ha ha
    Sooo the tank pull, I just put 3 gallons of gas in it today, it ran empty. I assume when I take off the grounds that it will drop enough for me to see on top with out taking apart the gas lines, etc?
    Is there enough room to drop the back end of it to see on top? With the trunk pan being rusty and some small holes I bet the paper is TOAST if it is there. Thus far I tracked the car from now back to 1996 in AZ, 93-96 in New Mexico.
