5gen 2012 Camaro center console in my 1970
Discussion in 'Interior Restoration' started by Tpichevy, Feb 25, 2017.
  1. CaliCamaro75
    CaliCamaro75 Veteran Member
    372
    22
    Sep 6, 2015
    Winchester,CA
    I was planning on shaping something to mold and fit underneath. Using the existing pieces. If I ever get to it I will pics. If it turns out nice
  2. 1971CamaroGuy
    3,621
    124
    Oct 31, 2004
    Arkansas
  3. 1971CamaroGuy
    3,621
    124
    Oct 31, 2004
    Arkansas
    Looks like another person made cell phone pockets out of that area...neat idea
  4. CaliCamaro75
    372
    22
    Sep 6, 2015
    Winchester,CA
    Anyone have an idea what the console is made of? Like plastic type?
  5. giggity
    giggity Veteran Member
    727
    21
    Mar 18, 2013
    Pearland, texas
    I just bought console from a wrecked camaro, 100 bucks, then bought RS bezel for manual tranny. I think Im going to really like the way this looks. I wont be doing interior for a while, but this will look sharp. looks like it belongs in there.
    My plans are to hook up the usb to power, to at least charge my cell phone. Also to make use of the traction control switch on the console for something, I believe its just a momentary switch. I like the cell phone idea for the e-brake!
  6. ULTM8Z
    ULTM8Z Veteran Member
    8,854
    220
    May 19, 2000
    Los Angeles
    Anyone do this with an automatic yet?
  7. CAMeeks
    CAMeeks Veteran Member
    660
    29
    Jan 5, 2014
    Deer Park, TX
    If it is momentary I'm using it for a trunk release. Bought the electric trunk release from Year One.
  8. 8pack
    2,446
    85
    Aug 29, 2007
    Pittsburgh, PA
    It is a momentary switch, but you push it 2x for two different levels in the original car. I am not sure it can be converted to another use without some additional electronic wizadry. I look forward to seeing what you come up with.
    The stock USB can be wired up, but I found it easier to pop it out and put an aftermarket 2 port charger in. I added additional chargers and used, power and ground distribution blocks to make all the attachments. I also hooked up the stock cigarrette lighter there as well .
    My build thread has pics etc.
  9. CAMeeks
    660
    29
    Jan 5, 2014
    Deer Park, TX
    More then likely it is just a momentary switch that when you push it the computer sees it and does a function. Then on the second push the computer does the other function.
  10. 1971CamaroGuy
    3,621
    124
    Oct 31, 2004
    Arkansas
    Could someone give me a rough estimate of what this measurement is? I wondering if it sits too low in that area for an automatic and the shifter assembly will stick up too high?
