5gen 2012 Camaro center console in my 1970
Discussion in 'Interior Restoration' started by Tpichevy, Feb 25, 2017.
  1. hot72rod
    I tried to get in touch with the company that made the insert, but never did hear back from them and I never did follow up.
  2. SS Performance
    SS Performance Veteran Member
    141
    19
    Nov 17, 2016
  3. hot72rod
    I don't even remember the name. It was about this time last year when I was looking.
  4. NOLAZACK
    NOLAZACK Veteran Member
    114
    14
    Feb 7, 2017
    Bump this. Im looking at adding this as well. Any info on this usage of the Horshoe shifter with a 2010-present center console is greatly appreciated!!!!
  5. Green hornet
    Green hornet Veteran Member
    1,520
    232
    Oct 11, 2015
    North Bay, CA
    Here is the photo I posted early in this tread (deleted thanks to photobucket) of the horse shoe shifter. The only thing I was able to find is that it may have been made by Tommy Pike Customs. Not sure if this helps anyone.
  6. SS Performance
    141
    19
    Nov 17, 2016
    I like the one in Smokeatr23's post better.
  7. buildinmy73
    buildinmy73 Veteran Member
    1,068
    8
    Oct 20, 2007
    Bernardston, MA
    Any ideas what to do with the ebrake hole if not using the pull handle and using my stock footbebrake ?
  8. CAMeeks
    CAMeeks Veteran Member
    684
    33
    Jan 5, 2014
    Deer Park, TX
    Some have made a leather pouch and put there for a pocket.
  9. CaliCamaro75
    CaliCamaro75 Veteran Member
    372
    22
    Sep 6, 2015
    Winchester,CA
    I was thinking of molding something out of abs plastic. For like a cell or something
  10. 1971CamaroGuy
    3,660
    133
    Oct 31, 2004
    Arkansas
    I looked at that in the pics, if I end up getting the console I was going to take that piece that pops out around the opening. St etch a piece of felt or grill cloth around it, apply some fiberglass resin. Let it harden, then smooth with filler and prime. Either texture or paint it with some sem landau black at same time I did the console to match my interior.
    Essentially making a blank plate to fit in there
    abs plastic would work, but you would have to try and shape it and cut to fit. By using the piece that pops out your getting the exact shape and something that will clip back in place.
