540 BBC swap '73 split bumper
Discussion in 'High Performance Modifications' started by RollzRoyce, Dec 17, 2017.
  1. Plant Engineer
    Plant Engineer Veteran Member
    347
    72
    May 17, 2017
    Washington State
    Yes . Its the 7622. Very nice well cast manifold. Much lighter than the Edelbrock Vic Jr. with a better finish.
  2. RollzRoyce
    RollzRoyce Member
    35
    Aug 19, 2017
    Sweet. I'll prolly get one of those too. Thanks again man, have a good one.
  3. fdeluca532
    fdeluca532 Member
    35
    Nov 7, 2007
    winthrop harbor,ill
    they have big block header for 1972 Camaro. I had a set hooker headers they fit great. They used to put bbc in camaro
  4. jpkerley
    jpkerley Veteran Member Lifetime Gold Member
    274
    11
    Jun 4, 2008
    MEMPHIS, TENNESSEE
    I think you would be surprised see Lil Red 406 posts with his 555. near identical setup as you. get the suspension right and high 9's will not be a problem. My build is almost identical. Straub Solid Roller though and 315s dynode in the high 700s and had a 700 tq table over several thousand RPM. I'm right at 10:1 port matched intake. Jessel shaft rockers. Nothing crazy. Vortech Pro has built a lot of 496 that make 700 hp and have run deep in to the 9s at 3500 lbs.
  5. LILRED496
    LILRED496 Veteran Member
    1,211
    Jul 14, 2008
    FLA
  6. LILRED496
    1,211
    Jul 14, 2008
    FLA
    His set up does sound like mine ,should run good.
    I still have the 2 inch headman headers .I took a saw to them and cut the small 3 inch collector off and put bigger ones on.
  7. LILRED496
    1,211
    Jul 14, 2008
    FLA
    9s shouldn't be hard. This is my current set up
    78 Camaro,3495lbs,BBC 555 with AFR 325s ,flat top pistons ,threw a 90lb 4 inch exhaust system with 4 mufflers and x pipe with 12,500 miles and 300+passes on the motor
    Driven 75 mile round trip to the track.Foot braked leaving from 1000rpm idle ,390 gears shifts at 6200-6500 rpm traps 6600
    UD Harold Hydraulic roller 3/4 pre load .660/.660 259@50 110 lobe sep ,still have the factory power brakes
    Rec 90 9.45 @140
    Rec 90/racegas
    1.303
    5.86 @116.4
    9.26 @141.7
    best 60 1.295
    best mph 142.09
  8. RollzRoyce
    RollzRoyce Member
    35
    Aug 19, 2017
    Cool thanks for the response, sorry. I didn't notice I had new responses a few weeks ago, too busy making $$$ to pay for this build. Lol...
  9. RollzRoyce
    RollzRoyce Member
    35
    Aug 19, 2017
    Cool, thanks for the response and your engine specs, good to hear about a similar setup running well. Sorry for the late reply, didn't notice a few weeks ago... Busy busy!
  10. LILRED496
    1,211
    Jul 14, 2008
    FLA
    No problem, recently got a new best
    with vp 109 that is 105 octane
    weather was 58 deg with 86% humidity DA was +593
    I couldn't get traction so I had to ease into it and broke up on the big end not sure yet what the deal is yet lean ? , anyways
    ran
    1.352
    3.797
    5.874@117.86
    9.245@142.24
    shooting for 9 teens within a few weeks then Im going gut it and drop the exhaust system hope for good weather and shoot for some high 8s
