427 Torque Monster
Discussion in 'High Performance Modifications' started by CNC BLOCKS, Mar 4, 2018.
  1. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,637
    Oct 11, 2004
    NORTHEAST
    Spent some time on the dyno yesterday on a SBC 427 build for a good friend of mine. He wanted a SBC with BBC torque down low for his street build. This engine laid out some impressive numbers.
    Was a very efficient engine only required 32 degrees of timing it did not like 34 degrees and it did not like 30 degrees.
    This is what I came out with and it was no budget build LOL.
    This is also on my F/B page with a lot of pics of the build https://www.facebook.com/cncblocks.northeast/posts/856106251235885?pnref=story
    This will be the only one of these I will build I can take it off my bucket list as I have wanted to this build for a long time and it came out as planned.
    Dart SHP block 3.875 stroke X 4.185 bore sonic tested 3 blocks and this one was the best one
    Callies Comstar crank
    Scat I beam rods 6.0
    Custom Wiseco dished pistons.
    Ultradyne HYD roller on a GM step nose core I used the GM spider and GM roller lifters reduced the base circle to 1.050 Lifters were quiet block need no oiling modification LOL
    AFR 210 heads 75 CC chambers
    Eddy Air Gap intake
    750 Quick fuel carb, Wanted to go to a bigger High speed air bleed but the customer said leave it alone it was fine.
    Scorpion 1.5 rockers
    Champ 8 quart pan
    10552 Oil pump
  2. mrdragster1970
    Look at all those engines!!!
    Any extra 700-800 inchers laying around you want track tested, I'm happy to help you out :D
  3. RS1979
    3,080
    420
    Jun 18, 2013
    Memphis, TN
    Impressive numbers for a small block without boost or nitrous
  4. camaro71/holland
    1,014
    40
    Aug 27, 2003
    The Netherlands
    Impressive numbers and quality work as always from you Carl, but don't understand the drama? You've built it, got the numbers, blue print specs and everything, so what would withold you from building another one?....
  5. CNC BLOCKS
    1,637
    Oct 11, 2004
    NORTHEAST
    I really don't do that many builds like that, I have plenty of blocks to machine and build a lot of circle track engines.
  6. camaro71/holland
    1,014
    40
    Aug 27, 2003
    The Netherlands
    Ok, got it. Maybe you've reached a point where your customer isn't the king any more....;)
  7. CNC BLOCKS
    1,637
    Oct 11, 2004
    NORTHEAST
    My customers are all Kings and Queens
  8. Zstar
    Zstar Veteran Member
    1,380
    286
    Mar 23, 2014
    Ocala, Florida
    That is a torque and hp curve to die for. Incredible numbers! You could make a fortune building these. Great build, congradulations! You have made your customer EXTREMELY happy. I would like one myself if I was 20 years younger.
  9. 77 cruiser
    77 cruiser Veteran Member
    497
    15
    Nov 17, 2006
    Frostbite Falls MN
    What's age got to do with it.;) how old are you?
  10. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    635
    19
    Aug 18, 2011
    Upstate New York
    If you told people how small that cam was they would scratch their heads. The dyno numbers look valid with only a 3% correction. Did you dyno this yourself?
    That is a true street engine that would be "traction challenging" for sure!
    CNC BLOCKS likes this.
