400 Block Up For Sale Locally
Discussion in 'Engine Topic' started by Bandit723, Oct 12, 2017.
  1. Bandit723
    Bandit723 Veteran Member
    2,663
    325
    Oct 1, 2016
    Waupaca WI
    Wondering if i should snag this thing supposedly has not been bored out so virgin bore. Have not seen these come up too often or saying that ever. He want's $400 for the block and includes 2 cranks and some type of ARP bolt kit.
    https://appleton.craigslist.org/pts/d/400-chevy-sbc/6342775493.html
  2. GoldenOne7710
    GoldenOne7710 Veteran Member Lifetime Gold Member
    4,426
    260
    Jun 23, 2004
    Athens, GA
    Is it the machine shop that's selling It?
  3. Bandit723
    2,663
    325
    Oct 1, 2016
    Waupaca WI
    No it is a private seller.
  4. Rdobbs1977
    Rdobbs1977 Huge Guns N Roses Fan
    283
    10
    Dec 1, 2014
    Nashville
    all 400s were externally balanced. Don't think he's got two cranks but he's just saying he's got a stock crank made by eagle as opposed to a 'stroked' crank. Big fan of ARP but don't need a stud kit really unless you're going to really put it to her on the motor down the road. Nonetheless, i'd rather have studs in any case if i had to choose. Like anything, its a roll of the dice when they tell you the block is good, no cracks, etc. We all roll the dice and come out good at times or bad. I like virgin gen 1 blocks so i'd bring a caliper with me to see for myself if you bit on this. better yet, if you've got a dial bore gauge, calibrate it to 4.125 and bring it with you. Lastly, i think the region an item sells in is basically the market. Around here in TN, i see 400s but they want an arm and a leg for them. $400 for the block, crank, balancer........not too bad but you could probably get him down a little..
  5. Bandit723
    2,663
    325
    Oct 1, 2016
    Waupaca WI
    I suspect this is an estate sale. I don't have a dial bore gauge but do have a caliper. I will give him a call. Hate to pass this block up if it is real especially if it is a 75 or older stamping
  6. Lowend
    14,506
    294
    Mar 25, 1999
    San Jose, CA, USA
    I'd wanna see paperwork from the machine shop before spending a dollar
    GoldenOne7710 likes this.
  7. Bandit723
    2,663
    325
    Oct 1, 2016
    Waupaca WI
    Well passed on the 400 block posted above it had some bad pitting where the oil goes and did not look to stellar when i peeked into the water jackets. But when it rain it pours another 400 can up it is out of a 77 GMC truck guy is saying it ran when he pilled it and only wants $250 for it.
    Just not sure it the 77 block is as strong as the older castings.
    https://appleton.craigslist.org/pts/d/chevy-400/6345625987.html
  8. 79RedZ
    79RedZ Veteran Member
    638
    27
    Mar 24, 2009
    Hamilton,MI
    That may have been pulled out of a 77, but it looks to be a wide pad motor, which means it was transplanted. That might be worth a little closer look.
  9. 79RedZ
    638
    27
    Mar 24, 2009
    Hamilton,MI
    It would be great if you could see the suffix code.
  10. Bandit723
    2,663
    325
    Oct 1, 2016
    Waupaca WI
    I will give him a call to look at it. Thanks!!!
