4 speed reverse lights
Discussion in 'Electrical Systems' started by BIG CHEVY, Nov 1, 2012.
  1. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    Mine is the same way. Works perfectly
  2. Jeep43
    Jeep43 Veteran Member
    Mar 30, 1999
    The bracket bolts to the rear shifter stop adjustment bolt on my Hurst Comp Plus. I assume the stock shifter does not have these stop bolts and you would have to find an alternate method to attach it.
    That or fab up your own bracket to mount it somewhere else.
  3. BigBlock73
    Jul 10, 2002
    Accord,New York
    I bolted the bracket using one of the shifter mounting bolts, and bent the bracket to fit.
  4. Rayden2009
    Rayden2009 Member Gold Member
    May 12, 2016
    Calgary AB
    Thanks. Ive done some invesigaing online and under the car and your right. Now im on the fence: do i rig up a stock solution for a couple hundred or bite the bullet and go hurst shifter.
  5. Smokey15
    Smokey15 Veteran Member
    Aug 13, 2017
    I just turned the column either to activate the reverse lights or remove the key. So I didn't leave the lights on while driving, I installed a "Reverse" light from a Mopar in my console. Wife's Nova has a lighted dash switch.
