4 core radiator lower cushions
Discussion in 'Engine Topic' started by Skip Fix, Dec 24, 2017.
  1. Skip Fix
    Skip Fix Veteran Member
    2,084
    Mar 21, 2007
    Katy,Texas
    Having some issues with teh 4 core cushions on the core support. The old 2 core radiator the "tit" was dead center. These are offset which is needed onthe upper but not working on the lower. Also the lower core support the hole looks centered in the 3.5" space, radiator is roughly 3 1/4 and the mount is way longer. DSC_0012.JPG DSC_0011.JPG
  2. 70-camaro
    70-camaro Veteran Member
    1,627
    263
    Mar 25, 2010
    marietta ohio
    Try those on the radiator top plate.
  3. Skip Fix
    2,084
    Mar 21, 2007
    Katy,Texas
    They are fine on the top, have a pair up there, but need the lowers replaces also.
  4. BigBlock73
    1,950
    32
    Jul 10, 2002
    Accord,New York
    Lower ones are different
  5. Skip Fix
    2,084
    Mar 21, 2007
    Katy,Texas
    I figured they must be, I just have not found them -have a source, part #?
  6. Skip Fix
    2,084
    Mar 21, 2007
    Katy,Texas
    Those look like the same ones. Notch on one end and offset "tit". I got these fro Classic that said needed 4 for the radiator.
  7. Itsadryheat79
    Itsadryheat79 Veteran Member Lifetime Gold Member
    282
    Aug 4, 2009
    Chandler, Arizona
    Try mounting them as the second pic and cutting off the EAR sticking out to the right. That's what I remember doing when I mounted a wider 4 core radiator in my 71 Firebird.
  8. Skip Fix
    2,084
    Mar 21, 2007
    Katy,Texas
    That was going to be my plan and maybe drilling an additional hole for the "tit".
  9. Turbo70Camaro
    2,129
    111
    Jan 7, 2005
    so cal
    I just cut off the nipple on mine and stuck the cushion on the radiator.
