383 Stroker? Engine rebuild
Discussion in 'Engine Topic' started by '71StreetZ, Oct 28, 2017.
  1. Lowend
    14,230
    202
    Mar 25, 1999
    San Jose, CA, USA
    Sounds like you've already got this under control.
    For the record, the street 383 conversion only adds maybe $400 (on the high side) to the 327/350engine rebuild cost.
    <recommendation removed>
  2. '71StreetZ
    '71StreetZ New Member
    21
    Aug 18, 2017
    the local place that built the 327 that is in my car offers a 355 long block starting at $2700 that they say will make 400+ which sounds almost too good to be true but the extra cubes will make a nice torquey street motor
  3. Lowend
    14,230
    202
    Mar 25, 1999
    San Jose, CA, USA
    I'd like to see their specs. It's easy to say something makes xxx horsepower
    I was just looking at the specs for the 350HO, and I'm rescinding my recommendation as I forgot that engine has a flat-tappet cam. With current oil specs, I would not recommend a flat-tappet camshaft in Chevy.
    I'm going to say this again for effect:
    I recommend against all flat-tappet cams in all Chevy V8's
    This Aluminum Headed Roller Cammed 383 is hard to beat http://sdparts.com/i-24080897-chevr...-350ci-fast-burn-385hp-base-crate-engine.html
    The Fastburn heads are damned good, and there's a ton of room to swap in a bigger cam later if you want more
    '71StreetZ likes this.
