32 X 50 BamaRockers Shop/ Jam room
Discussion in 'Garages, Workshops & Tools' started by BamaRocker, Feb 7, 2013.
  1. 5spd540
    12,339
    10
    Sep 19, 2009
    Guyton, GA
    Oh I bet you are itching to do that job.:) :shy: :shy: :shy: :shy:
  2. John Wright
    13,976
    49
    Aug 9, 2002
    Rustburg, Va
    OK, I see what you did there;)
  3. The Champ
    The Champ Veteran Member
    3,438
    147
    Sep 14, 2000
    MN
    I know for some, handling insulation is a PITA. For me, it's NBD.
  4. artgtr
    artgtr Member
    75
    Apr 20, 2012
    Wurtsboro, NY
    Awesome, looks great, what could be better than hot camaros/firebirds and guitars. I did something like you did only my music room ended up being to small, now it is mostly music equipment storage, my music room ended up being 9' wide and about 16' long. I'm also a music equipment junkie, collecting vintage fender/marshall amps. They do take up room. I mounted my PA speakers on the walls. I also put up a shelf at the ends high enough out of the way, with enough room to put guitar amps up on them.
    Well looks fantastic, good luck & make great music.
  5. K5JMP
    insulation is cake...
    at the end of the day take a very flat and warm can of Pepsi to the shower with ya..
    pour it on a washrag and wipe down several times before you shower... the pepsi is sticky and will actually pull the fiberglass fibers out of your skin... then take a cold shower so you don't open up the pores of your skin.
    old trick I learned working in a fiberglass shop rolling out body parts way back when.:innocent:
  6. Da-bigguy
    3,161
    36
    Jan 19, 2010
    Cypress, TX
    I will have to remember that trick when I next do some insulation!
  7. motown 454
    motown 454 Veteran Member
    406
    Feb 4, 2008
    Ma.
  8. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    2,804
    24
    Mar 13, 1999
    Brighton, MI
    Hey thanks, that sounds like a good idea! Insulation fibers bug me, too.
  9. danbrennan
    2,804
    24
    Mar 13, 1999
    Brighton, MI
    Nice door selection. And I'm jealous of the brick belt!
  10. BamaRocker
    BamaRocker Veteran Member
    562
    Nov 29, 2005
    Meridianville, Alabama
    Insulation done, Drywall next week....
