3" Exhaust to close to fuel tank vents... Advice needed...
Discussion in 'High Performance Modifications' started by Done Yet?, Oct 5, 2011.
  1. Done Yet?
    Done Yet? Veteran Member
    1,305
    Mar 5, 2010
    Fort Pierce, Florida
    I'm looking for some advice. My 3" exhaust comes too close to the vent lines exiting my gas tank. In the pic you can see the rubber hose comming from the vent laying right on my pipe. I tried to reposition the exhaust but still a no go. Right now I'm leaning towards pulling the tank cutting back the vents welding them closed and running a vented gas cap. The car is a 73, and the tank has 3 vents 2 on the r/s and 1 on the l/s. the Exh system is a Pypes Violator 3". I'm all ears for any advice on how to correct this problem in a different fasion. Thanks Guys Rob
  2. mgoad1971
    mgoad1971 Veteran Member Lifetime Gold Member
    2,471
    Jul 29, 2011
    Houston, Texas
  3. Pfrederiksen
    Pfrederiksen Veteran Member
    609
    Feb 21, 2011
    Edmonton,Canada
    Dump the exhaust behind the axle? (or is that not an option)
    P
  4. theflash
    11,015
    13
    Feb 27, 2004
    Podunk, CT
    The exhaust is what you need to fix, you should be able to trim it somewhere to make it fit. Why did you put in a 3" exhaust in the first place?
  5. Swanny454
    Swanny454 Veteran Member
    480
    Mar 9, 2010
    Cambridge IL
    Looks like the pipe needs moved toward the front of the car, looks like you have plenty of clearance to the axle to accomplish that with no real problems.
  6. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    I would move the tailpipe forward by cutting a small piece off and possibly relocating the hanger. That with maybe the elbow picture above and possibly a small dimple in the pipe should easily get you to where you need to be
  7. motorhead76
    motorhead76 Veteran Member
    558
    Oct 16, 2008
    MT HOPE WV
    May consider making a heat shield for it if possible. After you move it.
  8. 5spd540
    12,339
    10
    Sep 19, 2009
    Guyton, GA
  9. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Something isn't right with the way you have your exhaust put together. It shouldn't be near that close to your tank, and a tank is pretty hard to get in the wrong place.
    Try putting your tails in first, and work forward. Pypes stuff is pretty well engineered, but expect to do some cutting trimming somewhere, ususally between the muffler and headers.
  10. 79custom
    79custom Member
    86
    Sep 5, 2006
    Gastonia, NC
    I agree the problem is with the exhaust. I bought a cheaper kit and it was no where near the lines like that.
