2009 silverado upper ball joint questions
Discussion in 'The BS Topic' started by 80sz, Nov 4, 2017.
  1. 80sz
    80sz Veteran Member
    2,702
    268
    Feb 2, 2014
    Buffalo,n.y.
    Had my truck inspected this week. Found that I need a upper ball joint. They want 425.00 to do it at the chevy dealer. Seems pretty expensive. Watched a video on it and looks doable for the average joe mechanic like my self. Should I pop it out or do I just get a upper controll arm? I've got 99,000 on truck and it 4x4.
  2. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    1500 or 2500HD?
  3. 80sz
    80sz Veteran Member
    2,702
    268
    Feb 2, 2014
    Buffalo,n.y.
    1500 reg cab
  4. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    The control arm assembly is only 20 bucks more per side vs just ball joints in a.c. delco. Labor time in the book is 2.1, I can do both in under an hour. You will need an alignment afterwards. Get the arms. Avoid the mevotech ones, I've had to warranty a few. I prefer Delco.
  5. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    And list on the Delco arm is only 187.82, they must be getting 100 for the alignment and 60ish an hour labor? Or no alignment and 100ish an hour labor.
    80sz likes this.
  6. 80sz
    80sz Veteran Member
    2,702
    268
    Feb 2, 2014
    Buffalo,n.y.
    Thx for the help. They didn't mention a alignment. Price don't seem so bad now. Thx.
  7. Knuckle Dragger
    Knuckle Dragger Moderator Staff Member Lifetime Gold Member
    13,348
    493
    Nov 2, 2002
    Waddell AZ
    We've been directed to replace the control arms on the Tahoes.
    Run, don't walk from mevotech. We change the whole arm on the Tahoes with OE or Delco parts.
  8. Mike N
    Mike N Moderator Staff Member Lifetime Gold Member
    2,261
    276
    Jan 13, 2002
    Spencerport, NY.
    If the ball joint itself can be changed, do that. Unless your truck hasn't seen a bunch of salt (and I see you live in Buffalo) you may have a hard time getting the bolts that hold the control arm loose without a torch.
  9. 80sz
    80sz Veteran Member
    2,702
    268
    Feb 2, 2014
    Buffalo,n.y.
    Thx . I did take a look at the arm bolts ,they don't look bad. I want to skip the tool rental for the ball joint .
  10. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    Unfortunately, this is 100% correct. I still don't understand how anyone thinks that saving a few bucks on a part that lasts half as long saves money. The labor cost to do it twice always exceeds the cost difference to get a quality part.
