2 BOLT VS 4 BOLT MAIN POWER CAPACITY
Discussion in 'High Performance Modifications' started by nova75mike, Feb 19, 2018.
  1. budro6968
    budro6968 Veteran Member
    2,161
    287
    Apr 2, 2016
    Jax Florida
    This video of CNC Machine and they don't Torque Plate? why? Fascinating to watch. The machine does everything.
  2. ZEN357
    ZEN357 Member
    73
    12
    Feb 12, 2018
    Always go with a 4-Bolt main block especially if they are splayed. Just my opinion, always better to be safe than sorry.
    CNC BLOCKS likes this.
  3. nova75mike
    nova75mike Veteran Member
    319
    Mar 20, 2008
    Etters, PA
    Well, with the fact I'm going with a solid roller, and the rpm I'll be turning, it just made sense to spend the extra couple bucks now than chance losing a lot of expensive parts later when the caps shift on me. It will just delay the build for a bit longer is all.
  4. cweeet
    cweeet New Member
    Mar 28, 2013
    pine grove, pa
    i just went or am going through the same problem, found a great car with a bad motor. went with splayed 4bolt. callies rotating assembly. hope to have it fired in the next month. that being said if i had to do it all over again i would have just bought a 500 hp gm performance motor with a 24k mile warranty and forgot all about rebuilding it....
    anyway for the price i would say go 4 bolt. your going to have the thing at the machine shop anyway and when the motor hits 7 g's you wont hear it go boom.
  5. jimrr
    jimrr Veteran Member
    1,136
    246
    Jun 12, 2016
    sarasota
    wow, everything was done dry!!
  6. wiseryder
    1,983
    23
    Sep 11, 2004
    belding,mi USA
    I wondered the same thing..
  7. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,632
    Oct 11, 2004
    NORTHEAST
  8. CNC BLOCKS
    1,632
    Oct 11, 2004
    NORTHEAST
    With the added stroke 2 bolt mains do not like it seen it to many times over the years. When GM used a 2 bolt 400 block they left the register wide for more support for a reason.
    Before spending any money on putting splayed caps make sure you sonic test the cylinders to make sure you are starting with a good piece.
    Here is what I have seen when 2 bolt main block are used when good 4 bolt block should have been used.
  9. Rustbucket350
    Rustbucket350 Veteran Member
    807
    13
    Sep 4, 2013
    Oviedo, Florida
    I've only had one 350 block with a crack in the main webbing and it was a 4 bolt. It was a junkyard targetmaster motor with probably 200 hp. Every rod and main bearing was spun and the bearing material was in the lifter valley. With enough rpms and abuse you can ruin any block at any power level. I've had probably ten small block chevys on my stands in the garage in the past ten years but I've never seen damage like that.
  10. Lowend
    14,376
    253
    Mar 25, 1999
    San Jose, CA, USA
