1dirtyz's '70 RS build project
Discussion in 'Project Progress' started by 1dirtyz, Oct 2, 2011.
  1. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    I mounted mine under the car pass side, 1.5-2" gap from floor with rubber mounts. The picture angle makes it look close to driveshaft but it is not and the fan does not hang past the sub frame rail that much like in the picture angle.
    Yellow sleeve is kevlar based protection.....................
  2. 1dirtyz
    1dirtyz Veteran Member
    115
    Oct 2, 2011
    Riyadh , saudi arabia
    that's how I have it on my drag Camaro , but I can't do it on this one ; I plan on running a full dual exhaust on the car and that location is reserved for the mufflers :)
  3. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Good luck then ;)
  4. 1dirtyz
    115
    Oct 2, 2011
    a little update :
    managed to weld the wastegates to the elbows :
    and this is how they look on the car :
    I'm happy with how symmetric they look and how well the vent tube from the wastegate will reach the exhaust down pipes.
    so next up like I mentioned before , is removing the piping and intercooler , cleaning the insides of them , powder coating what needs to be powder coated , re installing everything, then installing the nose back on and figuring out the hood latch .
  5. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Are your wastegate down tubes gonna be free hanging or plumbed back in?
  6. 1dirtyz
    115
    Oct 2, 2011
    the plan is to have them snake back under the turbo into the down pipe.
  7. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    May I suggest welding on some gussets to the wastegate pipes, hanging out like you have them with heat cycles will fatigue the pipe and start cracks.
    Plumbing the exit ports into downpipes may help support the units though..........................
    example on my car, the gates hang low so I had to put extra supports (gussets)...........
  8. 1dirtyz
    115
    Oct 2, 2011
    thanks for the tip,,, I will definatly look into it !
  9. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
  10. 1dirtyz
    115
    Oct 2, 2011
    not really ,
    been busy with a bunch of other stuff and projects.
    I should get back into it again real soon . the plan is to finish the cold side piping completely ( meth nozzles , bov flange , poweder coating , etc.), then install the nose and start working on the hood latch and rad hold down. after that I should start on the down pipes and associated stuff :)
