1981 Z28 Need a Mild Cam Advice???
Discussion in 'Original Drivetrain Topic' started by Kae450, Feb 5, 2018.
  1. Kae450
    Kae450 New Member
    Feb 5, 2018
    Looking for a little more power. Want to keep my car as stock as possible. So I'd wanna run the factory carb and heads. What's a good little cam to give her a little more power? I'm willing to add headers too which ones should I get? Car will have a stainless exhaust with cats. Engine is a 350 by the way. Thx guys
  2. wilcar
    wilcar New Member
    Feb 3, 2018
    Take a look at an Isky 262 super cam, has 208-208 dur @ .050 .425 lift 108 LSA. Can use stock springs. Lots of low and mid range. Works good in a stock set up like you have.
  3. Zspoiler
    Zspoiler Veteran Member
    2,893
    186
    May 6, 2012
    Federal Way, Washington
    I had good luck with my 1979 Z-28 RS when it was stock.Or maybe an L-82 Corvette cam as well.
  4. Kae450
    Kae450 New Member
    Feb 5, 2018
    Thanks I'll look into that cam. Now if I could only figure out what red interior my red on red z28 actually is. I want all new carpet and plastics etc
  5. Zspoiler
    2,893
    186
    May 6, 2012
    It depends on the year and what was offered. to get some idea .Or make your own color
  6. ULTM8Z
    ULTM8Z Veteran Member
    8,887
    230
    May 19, 2000
    Los Angeles
    262 is a really good choice
  7. br80z
    br80z Veteran Member
    511
    Apr 6, 2001
    Fuquay Varina, NC
    I used to run this camshaft on a 81 camaro with 350 engine, stock Th350 trans and 3:42 gears. Other than the cam and flat top pistions the engine was a stock rebuild and ran great on the street with an almost stock sounding idle. The idle got a little lumpy after I later upgraded to long tube headers, that car was my daily driver at the time. Since then I found that calling the Lunati tech support is great source for help on a cam selection, just be prepaired to answer a lot of questions.
    http://www.summitracing.com/parts/sum-1102
    Basic Operating RPM Range:1,500-4,000
    Intake Duration at 050 inch Lift:204
    Exhaust Duration at 050 inch Lift:214
    Duration at 050 inch Lift:204 int./214 exh.
    Advertised Intake Duration:278
    Advertised Exhaust Duration:288
    Advertised Duration:278 int./288 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio:0.421 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio:0.444 in.
    Valve Lift with Factory Rocker Arm Ratio:0.421 int./0.444 exh.
    Lobe Separation (degrees):112
