1980Z redneck-touring vortec/6spd
Discussion in 'Project Progress' started by woody80z28, Feb 22, 2008.
  1. John Wright
    14,073
    66
    Aug 9, 2002
    Rustburg, Va
  2. woody80z28
    5,455
    15
    Sep 8, 2004
    walton, ny usa
    Been too long since an update...but it's coming along. I need to quit racing the Beretta! haha Well, after this month...cause I'm taking it back to the strip. I figure if I break it again it will be a kick in the ass to get this car done.
    Finally got some time to finish modifying my subframe. Got a bunch of stuff from John at Lab-14.com to strengthen it. Plates and studs for the UCA mounts, thick washers for the LCA mounts, plates for the body mounts, adjustable braces for the UCA studs. Saved a ton of time. I wish I had seen his site before I had done so much of the same stuff myself. I wanted to do the sway bar plate because I think a welded nut is a better solution than drilling and tapping a plate like I did, but I was not cutting off the plate I already fully welded on. But I did cut and weld the big UCA/shock mount as suggested.
    I also scoured through the depths of McMaster for some other mods I had planned. I welded a coupler nut inside the cross bar at the front of the frame horns. I figure I can use the bolt as a jacking point to get the front end in the air. Might work for a tow hook mount, too. I'll find out soon. The only problem with that big bar I welded in is the access to the radiator mounts, so I welded in some cage nuts.
    I've got some more stuff to update, but I'll wait until the new parts are here on Tuesday. I will say that the deep spring bucket of the DSE arms made it impossible to install my Hotchkis coils - even with a coil cut and compressed as far as my compressor would go. So you can probably guess where this is going...
    BTW, anybody need some Hotchkis coils?
  3. ChevyReb
    3,782
    Feb 4, 2003
    SC
    Man I never even thought about a lot of the mods you are doing! Very cool stuff.
    On your coil springs don't use the compressor like you have in pic. Take the top wing off and just use the bottom. Run the top rod up through the shock tower hole and use a washer and nut and run it down with an impact gun. It will suck the spring right up in there. I had pics in my build thread but I think photo bucket nixed that but I'll see if I can find them. I used heavy rachet tie straps and a floor Jack to pull the lower control arm up and chained the spring for safety.
    What are the knurled bolts for in the closeup pic where the lab 14 decal is? It's been a minute since I worked on my car and can't get perspective on it. Also on the washers welded in where the body mount bushings go did you have to get special ones from lab 14 since it is thicker there now?
    Great update!
  4. woody80z28
    5,455
    15
    Sep 8, 2004
    walton, ny usa
    I actually tried to get the compressor stud through the shock hole but it's too big. I may have been able to cut the stud off shorter and get it to work, but my dad has a first gen that is gonna need the coils R&R so I just gave the tool to him. My fix is more expensive, but I really wanted to go adjustable shocks anyway...and I picked up what I need during a Labor Day sale so the price wasn't too bad.
    The body mount reinforcements are welded on the bottom side, so the height of the body bushing is not affected.
    Those knurled bolts are ARP wheel studs for the UCA shaft mounts. John has it all figured out and they come with instructions. I welded washers on the inside too since my adjustable arms won't need shims and I can keep the studs shorter. The washers are welded so I still get the full knurl strength even spacing them back. This pic shows how it all works together with the braces to keep it all rock solid with the g-braces. The cantilevered subframe needs a lot of bracing to be stable.
    And since I'm adding more pics I'll show more of the progress to where I am now. I hit the chassis stuff with epoxy and Raptor Liner. Made a couple changes to the firewall after my last mockup too. The Raptor really gives a nice look, and the texture hides some imperfections.
    The bracing is a tight fit, but it works with the stock PS lines and the AN-6 setup I'll be running.
  5. woody80z28
    5,455
    15
    Sep 8, 2004
    walton, ny usa
    Long time no update. Been working on my Beretta since I kissed the valves off the pistons on a missed shift...oops. But now that car should be about 270hp instead of 200. haha
    I do have a bunch of old photos that I never did post for some reason. So here they are.
    I picked up a set of double adjustable Viking coilovers from UMI. Went with the 550lb springs. My old Hotchkis were 600 (which I still have if anyone is interested) but I can adjust the shocks stiffer when racing with these. (And way lighter for drag racing.)
    I also did have to change the stock 6" length idler from ProForged to the Howe on "for threaded sleeves" meaning heim-style tie rods. The PF piece is really nice, but caused the tie rod bolt to hit the LCA bolt on the crossmember.
    I also got some bumpsteer studs from Speedway for the knuckles. With the locknut barely catching threads they are really close, but I'm sure the correct adjustment will not be at the very bottom.
    John Wright likes this.
  6. NOT A TA
    NOT A TA Veteran Member
    172
    43
    Feb 12, 2009
    Delray Beach Florida
    It's coming along nicely Woody, keep at it! The shiny new coil overs and other bits look nice against the black.
  7. John Wright
    14,073
    66
    Aug 9, 2002
    Rustburg, Va
    You'll enjoy those Vikings....I really like mine.
  8. woody80z28
    5,455
    15
    Sep 8, 2004
    walton, ny usa
    JW, what spring rate did you go with? Done any drag or autocross with them? I'm hoping they'll be good to set medium for street, heavy for autox sms light for drag.
    JP, I'd actually love they spray that shiny crap gunmetal, but don't want to mess with the adjustment threads on the shock body. My new Tanks Inc EFI tank also looks shiny and gross... But that one is definitely getting a coat of paint. Haha
  9. Schubitzky
    Schubitzky Veteran Member
    305
    Mar 10, 2003
    Maryland
    woody, have you had a chance to put your tanks inc. tank in yet? Any thoughts on the quality or any problems with it? I need to do something with my tank and I've heard mixed reviews about them, but not sure what other options there are at the same price point.
  10. woody80z28
    5,455
    15
    Sep 8, 2004
    walton, ny usa
    I did test fit my Jakefab fuel puck and Classic Instruments gauge sender, but it's still dry. I got some photos of the baffling - looks like it should work really well. I was going to use a Holley HydraMat as my pump sock just to have a failsafe if the baffling sucked, but I doubt there is a need. The fuel "bucket" stays filled via a 3/8 fuel line at the bottom with a 90 bend in it. There are also large vertical walls in the rest of the tank with probably 1" or so holes in the them.
    BTW, that must be you I saw at Carlisle running the autocross. I was the one taking 5th from last with my Beretta. haha
    And speaking of Beretta...here's my Camaro update. It's been a shelf while I refresh the 3400. Kissed the valves off the pistons after a missed shift, so it's getting heads, cam and intakes from Wot-Tech and a trans once over. You know how that snowballs. Berettafest this year hits the Milwaukee Mile, Great Lakes Dragway and a huge autocross at Miller Field. So the ~200 to ~270hp jump should be a nice change.
